Question about Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
Hot water tank doesn't stay on - Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
    Sergeant:
  • 222 Answers
Suspect the thermocouple that senses that the pilot is lit. This device prevents the gas burner from coming on when if the pilot goes out, but if it's defective could cause the burner to shut down even when there is a pilot flame. Also check the position of the thermocouple in relation to the pilot flame. The tip of the thermocouple should be right in the middle pilot flame.
Posted on Oct 15, 2013
1972 atwood water heater
Check your propane tanks (are they full?), make sure the valve is on, then check to make sure gas is making its way to the hot water tank, if the pilot lights but won't stay lit your flame sensor is faulty.
May 14, 2014 | Water Heaters
Hot water is not staying hot
Is the control that operates the pump located in the storage tank? If so the pump not be pumping. A few factors might be needed to solve the issue.
Dec 18, 2013 | Taco 006-B4 1/40 HP Bronze Circulator Pump
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
Water heater
Hey Debora.
Give me more information. Add a comment.
What type water heater? Brand, type and model appear on label on side of unit.
Is this a gas or electric powered?
What exactly is happening? Water too hot. Water doesn't stay hot very long? No hot water?
Add a comment please.
Sep 08, 2012 | Water Heaters
Hot water from the tank is only warm, Temp on the tank is at Hot
does the flame stay on all the time? sounds like bad gas valve/thermostat
Feb 24, 2012 | Water Heaters
It is leaking out of the top. not out of the hot or cold valves but out of a nut by the cold side.
Your tank is rusted out and needs to be replaced.
Link below is a troubleshoot for leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
Protect yourself first:
If your tank is rusted, there is danger of rupture.
My friend welded his leaking tank, but he assumes the risk.
Ruptured tank can cause massive damage and water runs until it is shut off.
Hot water tank is under pressure because hot water expands and pushes against tank wall.
Turn off water to tank.
Turn off power supply:
Electric: turn off circuit breaker.
Gas: rotate knob to pilot so pilot stays lit but burner will not fire. To turn back on, rotate knob to ON.
Open hot side bathtub valve and relieve pressure on tank.
You can limp by with rusted tank by turning water heater on when hot water is needed.
Shower uses 5-9 gallons hot water
Bath uses 12-15 gallon hot water
Ordinary gas heater makes 41 gallons hot water per hour
Ordinary electric heater makes 20 gallons hot water per hour.
I buy water heaters at Lowes, Home Depot, Ace.
Look for scratch and dent models.
Buy drip pan for water heater.
Wrap electric heater totally with insulation except TP valve.
Buy new flexible connectors for water lines.
Offer 15% less than marked price on tank, because the store makes money on additional items.
> Most people can install their own electric heater since you just connect water pipes and electric wire, and it's done. Read link below since there are tips that help you buy and install electric.
> Generally people are nervous about installing gas water heater, so step-by-step instructions are shown on link below. Remember gas line is under less pressure than water line, so if you can install a water pipe, you can install gas line to water heater with crescent wrench, and soapy water to check for leaks.
How to install gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater, or any do-it-yourself project.
Jan 13, 2011 | Water Heaters
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
I have a rheem hot water tank when you turn on the hot water it comes out nice an hot but not even 30 secounds after that the water cools off and it stays as just warm water. I hear the gas kick in to heat...
Could be your thermostat but it might be your inlet dip tube. Your water heater has a plastic pipe that carries the cold water to the bottom of the tank. When you open your tap, it takes the hot water from the top of the tank, the cold goes to the bottem and gets heated. If this tube breaks, or comes loose, it will short circuit the cycle. The tank is hot but as soon as you start using water, cold water comes in at the top and mixes with your hot water, giving you just warm water. If you have room above your tank, you can remove the union on the cold side , screw out the pipe nipple, and look inside and see if there is a tube. If not you can buy one from home depot or lowes for just a few dollars. Also a water heater should be partially drained annually to remove any solids from the bottom, which will allow better heat transfer.If you find bits of plastic when you do, then you know where your dip tube went. Also if you've had a hot water faucet stop up and it looked like plastic there it is.
Jun 21, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
What to do if water gets inside hot water tank fluke..and what may happen when the tank fire dont stay lit?when tryinig to lite it
sounds as though you need a "thermo-couple" replacement to make the flame stay on,.......tryin to keep ya in hot water, cracklin joe
Jan 04, 2010 | Emerson InSinkErator C1300 Chrome...
Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
106 people viewed this question
Top Audiovox Water Heaters Experts
paulcarew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
