Question about Easy Quick Auto Jumper Recharges Vehicle Battery Without Jumper Cables
1999 saab 9.3 makes clicking sounds and won't start. It starts after 10 minutes or it might start after 3 hours panel say key latch acc*
    Master:
  • 452 Answers
Sounds like sticking contacts on starter motor will need to b removed and checked ,repair or replace starter motor the carbon brushes usually were down and don't make complete contact, just to make sure check and tighten batt terminals and connections on starter motor and earth wire on chassis
Posted on Oct 11, 2013
  • Jon Dow Apr 27, 2014
    I had a weak battery that caused similar symtoms. As the battery heatd up it would produce more power and eventually would start the engine. Battery was strong enough to crank the engine but the voltage drop was so severe, it would not operate the engines computer and hence sould not provide the spark.
Saab 9-3 1999 Car wont start turn key nothing happens
1. Try locking and unlocking of the doors five times with the remote to reset the immobilizer.
2. Key in ON position push Open button on key fob.
Jan 29, 2014 | 1999 Saab 9-3
My 1999 saab won't start right away it makes a clicking sound and after moving the drive handle up and down it will start sometimes after 10 minutes or 3 hours depending on the whether
Could be a neutral safety switch or sounds like even a "dead" spot in the starter motor itself, may be try tapping on the starter with a piece of wood or rubber mallet. Don't recommend a metal hammer to tap with may cause damage
Oct 11, 2013 | 1993 Honda Civic 4 Door
Hatchback won't lock on saab 9-3
I had the very same problem with my 2002 Saab 9-3 after I manually moved the trunk latch to the locked position "out of curiosity..." Then I noticed there is a handle you can pull to release latch opening it up! Very simple remedy... It is a glow in the dark green plastic handle hanging down when the trunk/hatch is open dead center, just in slightly behind latch... Gently pull handle until you hear and see the latch click into the open position...Let me know how You make out. BTW: Toyota Camry has the same set up,same color as well...lol Good Luck!
Oct 16, 2012 | 2002 Saab 9-3 SE
I have a Saab 2.2tid linear (2003). the central locking system has just stopped working completely, there was no warning to suggest its the battery in the key.. before it stopped working altogether it used...
THE SAAB 9 -3 REMOTE BATTERY HAS TO BE REPLACED AND REPROGRAMMED AT THE DEALERSHIP.THE SAAB 9 - 5 YOU COULD REPLACE REMOTE BATTERY AND REPROGRAM OR SYNCHRONIZATION BY PRESSING REMOTE KEY BUTTON UNLOCK BUTTON AT LEAST 4 TIMES TO REPROGRAM KEY REMOTE TRANSMITTER.
Mar 04, 2011 | Saab 9 3 Cars & Trucks
The key is stuck in the ignition and it won't turn on
Hello, if you're still having this problem it sounds like it is most likely your ignition "switch" itself. This is generally a $300.00 fix at your local Saab dealer however you can replace it yourself with a moderate level of mechanical knowledge. I'm assuming you have the encoded blocky non traditional looking "key" with a backup "traditional" key stored within. This key contains a code which is picked up by the CIM releasing the steering lock and allowing you to turn the key and start the vehicle. In Saabs infinate wisdom?? They found it appropriate to place this delicate electrical device within inches of a cup holder and high probability of being drenched in whatever your beverage at the time happens to be (usually coffee or soda). This can cause failure of the unit, requiring replacement. Are you able to hear the "click" (steering lock release) when you put the key in? Does your message center display any information? "Steering lock malfunction" "key not recognized"? I'm willing to bet that the problem is likely in this area. I do have a used (in good working condition and in nice shape) spare ignition switch and key if you determine that this is what you need. You may contact me at mpdmarysix@hotmail.com or take your car to your local Saab dealer to be diagnosed.
Nov 21, 2009 | 2003 Saab 9-3
Saab 93 will not start
Hi
I have had this problem with my 2003 Saab 9-3 for a little while now. I would drive it to the shops or the gym and after an hour or so return to the car and it fails to start. The lights indicate all checks are OK but the car will not start, no sound, nothing. It then magically starts after 20 - 30 minutes. This normally happens during hot weather. Any advice is very much appreciated.
Nov 11, 2009 | 2004 Saab 9-3
Action script
I tried your script and it all checked out fine when I ran it. Make sure you click on the first frame of layer action and open the Action Script Panel (F9). Once this is accomplished. Click on the second frame of layer action and press F6 key. Like I said everything worked out when I tried using the script you posted so, if anything I would suggest starting from scratch.
Aug 24, 2007 | Macromedia Flash MX
Easy Quick Auto Jumper Recharges Vehicle Battery Without Jumper Cables Logo
69 people viewed this question
Top Problem Solvers Vehicle Parts & Accessories Experts
Kathleen Brown
Kathleen Brown
Sam Akber
Sam Akber
17 SOUTH INDUSTRIES
17 SOUTH INDUSTRIES
Are you a Problem Solvers Vehicle Part and Accessory Expert? Answer questions, earn points and help others
