Question about Freezers
I have 2 big old chest freezers--Kenmore 122 and Coronado 193. The doors on both of them will not stay open whenever I put in/take out items. I assume it is in the hinges but how do I fix them?
    Sergeant:
  • 216 Answers
These models have a spring built into the hinges. You can remove a hinge and take the spring out and try a local hardware store or online @ Graingers
Because replacement parts are hard to find for these I have seen folks us the hydraulic hatchback shocks to assist in opening the lids and holding them open. Other have just made a prop rod similar to a car hood support.
Sorry I couldn't give you a direct link to replacement parts, But I tried my best to find these springs.
Best of luck!
Posted on Oct 17, 2013
dididsaythat
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
watugot
  • 290 Answers
SOURCE: kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Posted on Sep 25, 2007
bobotfel
  • 236 Answers
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Posted on Dec 28, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
  • 61 Answers
SOURCE: freezer not freezing
it would apear the stat is the fault. the thermostat is monitoring the temperature of the inner liner and tubing. if the compresor isnt actuly staying on the only part controling it is the stat. if you have the knoledge i would sugest you bypass the contol with the unit unpluged and the plug it in to conferm the fault was the control. p/s you may have a friend who has some knoledge . the control is a simple switch. just enshure the unit is unpluged. hope this helped
Posted on Oct 20, 2008
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, wgheaven@yahoo.com.au Russ
Mar 28, 2011 | Whirlpool Freezers
We have an ancient Kenmore Chest freezer. I don't know what the orange, green & red lights mean. Also which is "ON" 0 or -
the light tell you if the door is closed properly or not . Close the door tightly and check the lights. Then open it and check them again this will tell you the positiopn of the door for each colour
Oct 06, 2010 | Kenmore Chest Freezer 16082
Foul fish smell emanating from the freezer
Well an old remedy is to put a box of opened arm and hammer baking soda in the freezer and fridge to keep it from having bad odors.If that doesn't work you can try some charcoal it is perfect for absorbing odor, just don't use the matchlight kind or it will smell like lighter fluid.
Apr 06, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Have lost instruction booklet and do not know how to defrost.
Easiest solution is to get an ice chest and put all your frozen items in it and turn the unit off or unplug it and leave the door open and let it defrost itself. If you really want to speed it along use a hair dryer to speed up the process. Or put a circulating fan in front of it and put it on high facing the inside of the freezer.
Remember folks KISS, "Keep it simple stupid"
And No I'm not saying anyone is stupid.
Mar 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer not keeping foods frozen
If this freezer is running all of the time and only freezing the walls at the top inside it is a good chance there is deteriation in the piping in the walls eg (rusty pipes) letting the refridgerant escape (common fault) with chest freezers.If it is more than 7 years old it would be advisable to replace it as the repair would probably cost 3 quarters of replacement price.Hope this helps. Kind Regards.
Nov 27, 2009 | Woods 4.3 cu. ft. / 122 liter Chest...
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Chest freezer lid repair
if your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
it is a bastard of a job, and i wish you all the best.
May 01, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
81 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
