Question about Garden
Quits working - Garden
  • 7,482 Answers
Hi Fast
To make sure you are getting spark at the spark plug,do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the distance between the flywheel and the coil and be sure to
install the new one with the same clearance
Normally the clearance is around .18 thousandsands...(you can also use a business card for the measurment)
Or write the measurement down on a piece of paper for later reference, this measurement is critical to starting of the engine later.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion
from the magnet area.
You can also try to lightly sand the module metal face to increase the possibility of ignition of the old module before replacement.
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphragm that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Bud
Posted on Oct 12, 2013
My 2003 gmc Sierra driver side door panel quit working, locks quit, seat heater quit, windows quit, passenger side works fine
The most likely culprit is your driver's door control module... it's built into the driver's window switches. Double-check all your fuses before replacing any parts.
Jan 27, 2013 | 2003 GMC Sierra 1500
Speedometer & odometer both quit after working intermittantly over time. For some time the odometer worked when the speedometer would only work once in awhile.They finally both quit together. There is...
if one or the other quit working and then both quit working then i would have to say by looking at the electrical diagram that it would be the speedo head itself. it sends only one signal to speedo head that the vehicle is moving so if one was working and not the other then the sensor in the trans should be doing its job but if both had quit at the same time i would say sensor in trans. good luck hpe this will help you let me know...................
Jun 18, 2011 | 1994 Toyota Pickup
My speedometer and odometer quit working. I replaced the sensor on the transmision and it didn't fix the problem. By the way, the part cost me $174.00 + tax. That was an employee price sence I used to be a...
The odometer quits working when the speedometer quits working. The most common cause for the speedometer to quit working is the speed sensor in the transmission. You said you replaced it, there is also a transmission speed sensor on your truck that may need to be replaced. I understand your frustration, but there is nothing else that would cause the speedometer to quit except the cable behind the gauges being clogged.
Sep 07, 2010 | 1993 Toyota Pickup
I can't select a cycle. The buttons quit working.
it sounds like the touchpad is gone,phone the manufacture and see how much it will cost ,and then take it from there
Mar 30, 2010 | Maytag 24 in. MDB7601AWS Stainless Steel...
Ac/heater blower quit working power windows quit working wipers quit working radio quit working all at the same time 2004 grand caravan
check main power panel under the hood for aux fuse, should be in the 40 to 60 amp range possibly slightly larger than standard fuses.
Nov 26, 2009 | 1999 Dodge Caravan
Heater quit working (would only
Sounds like your auto climate control module.
Aug 11, 2008 | Mercedes-Benz E-Class Cars & Trucks
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
