Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
Door seal warm
Door seals on ge side by side profile feel warm. is this normal?
    Top Expert:
  • GE Master
  • 9,472 Answers
YEs, this is normal.
Posted on Oct 12, 2013
    New Friend:
    Problem Solver:
  • 7 Answers
Mitch,
The seal (aka: Gasket) is what keeps the cold air in your unit. 99% of gaskets have a magnet inside to help hold the door closed. Most gaskets are made out of a PVC material and can withstand the cold temperatures of residential and even commercial freezers and fridges. The don't often get too cold as they could get brittle too quick and crack which would lead to air and condensation build up in your unit. If you are in need of a replacement gasket. Visit us at www.gasketguy.com or give me a call and I can help locate the right gasket for you.
- Nicole
1-877-442-7538
Posted on Dec 18, 2013
4 Suggested Answers
Techsim
  • 59 Answers
SOURCE: GE Profile Door Seal
There is a cam at the top of both doors the grab on to the fridge to hold the door s shut. There has been a problem with them breaking and not holding tight. Check the door and make sure the cam is gripping the cabinet correctly.
Posted on Nov 02, 2008
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
DeBruce
  • 145 Answers
SOURCE: Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Posted on Mar 05, 2010
I have a 3 yr old ge Profile side by side refridgerator model #psc23sgrdss with the following problem. on 3 occasions in the last 3 wks I've found the temp. in the refrig section very high ( 56 degrees and...
I had same issue this past week. Refrigerator up to 45 freezer up to 15. Ice would melt and then everything would get cold again. Ice formed on everything. Next thing you know it was warming up again. I knew the rubber seal on door flap that opens to let ice out warped during summer months because I keep it 78 in summer. Had that replaced today. Temperatures have gone back to normal and stayed ALL DAY (knock on wood). Check door flap seal sticking your hand up making sure you don't push in the water tab. You should be able to feel if it is warped/wavy like an old LP or not. Good Luck.
May 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Side by side ge profile freezer is not cold and metal strip is warm between doors
Clean the seal with soapy water and a dish brush (especialy in the folds) Dry the seal and use a dollar for the test to see if the seal is working everywhere. The seal may need to be aligned by pressing the 3 directions ( you will feel it pop in place. If it still leaks use silicone gerase from the plumbing dpt. at the hardware store.
Aug 18, 2009 | Refrigerators
R door- GE 21.6 is slipped down. Gasket cant seal, part needed?
the parts detective dot com has all sorts of repair parts. You'll need the model and possible the serial number.
Aug 11, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
My freezer also just jumped to 17° and won't go down to 0.
We need to check the evaporator fan and the condenser fan. The heat in the door frame is normal when the refrigerator runs normally. But when a control board or fan fails the heat may increase because they are heat strips behind the door or condenser lines placed there to prevent moisture around door seals. We also will need to unplug and have a look at the mother board on back behind a panel. Many times the board will show burn marks on the back or front. When you are ready let me know, Thanks, Sea Breeze
Jun 18, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Refrigerator door is not shutting right
You need to replaced the door cam assembly on the bottom of the refrigerator side. It is probably cracked and hanging up.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_e97a69269ae71345
Jan 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
89 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
