Question about ZEEPAD 7 inch Android 2.2 Tablet
The outside speaker wont work on my zeepad but the headphones do i have tried messing with the settings and the volume settings and still nothing. Is there anything i can do to fix this or do i have to send it back?
2 Suggested Answers
  • 81 Answers
SOURCE: How would i fix the Wifi on my Zeepad? The Wifi will not work at ALL i have done 2 factory resets
I had the same problem. On a Hisense tablet. My daughter fixed it she didn't give up her secret but she downloaded an android firmware app. I believe that may have solved my problem. Believe me I tried everything before she took it home
Posted on Apr 06, 2015
No sound on tablet worked before I pluged in headphones now headphone icon on and no sound at all non from headphones or speakers
I looked everywhere for an answer and tried it ALL, from cleaning the jack port, reboot, restore to fabric options, and many more, but none of them worked. However, as I was trying not to go crazy trying so many weird things on my new not properly working tablet, I accidentally found the solution!!! why it works I don't know, but it does so here it goes:
1. Turn device off
2. Make sure your headphones are plugged ALL the way in (you should hear a click sound)
3. Press the on/off button and the volume up button at the SAME TIME
4. Once the screen is on let the on/off button go
5. DO NOT let the volume up button go
6. Wait until the tablet has finished loading all settings up.
7. Let volume up button go.
THIS IS WHAT I HAVE JUST FOUND ON THE ENTERNET BUT THIS IS NOT TO SAY IT WILL WORK FOR YOU.SO PLEASE THINK ABOUT WHAT ITS SAYING BEFORE YOU TRY IT.
I DONT WANT YOU TO MESS UP YOURS...IF YOU DONT WANT TO TRY THIS THEN I WOULD SAY LOOK AROUND THE ENTERNET FIRST JUST TO MAKE SURE.
Nov 08, 2016 | Tablets & eReaders
Speakers do not work. Headphones do. Tried adjusting volume but nothing changes
Possible causes are:
faulty conections on speaker cables, check all conections.
cable damaged, replace cable
speakers faulty, replace speakers
Feb 03, 2016 | Dragon Touch Touch7 Blue Dual Core Y88...
Why is sound not working?
which sound,? SPEAKER RINGER OR EARPHONE?
try with headphone,,,,check if there is headphone sign on display without headphone?
Jun 23, 2015 | Samsung Galaxy Tab on 3 Mobile Tablet PC
My zeepad tablet wont connect to my WiFi
This may be a firmware problem. I had this problem. Download a android firmware app. Actually it's called android firmware and updates app and it's free. I don't think these cheaper tablets update as they should, that causes them to not connect to the internet. Why? I don't know. It drove me crazy. I tried everything. My daughter figured it out after messing with the tablet for months.
Mar 09, 2015 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
My volume is relly low even wen its at max pleasehelp
I can't figure out what you are asking. Can you rephrase your question? What operating system are you using, Win7? If so, try right-clicking on the "speaker" icon found in the system tray (lower right hand side of screen) and select 'Open Volume Mixer' option. Make sure all settings are not set to minimum. It could be another config setting. Explore other options under the "speaker" icon.
Good Luck.
Jan 23, 2015 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
Why when I turn on my zeepad screen is blank battery is fully charged the green man shows then blank screen?
Hi, try a Hard Reset!
Normally, you have to hold one of the volume buttons down while powering on the device(try them one at a time). If you get a screen that says something about download, try the other volume button.
Once the device has booted to the "special recovery" menu, this is controlled by one of the volume buttons to scroll through the options and the POWER button acts as an enter key. Be on the lookout for an option that says something about "restore factory settings" and select that!
Oct 18, 2014 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
How do you reset the zeepad when it wont turn on?
It is different depending on which zeepad you have. From powered off, which yours sounds like it is:
1. Hold down both volumes and power at the same time. You should get an android on its back opened up.
2. Press both volumes at same time to open up a small blue text menu.
3. Then use Vol - and Vol + to navigate the Recovery mode.
4. Select "Factory Data Reset"
5. press power
6. choose "yes" from the menu
7. then press power again.
If this does not work try holding down the volume and power at the same time.
Aug 10, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
How can I reboot my Zeepad?
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
May 16, 2014 | ZEEPAD 7 inch Android 2.2 Tablet
How do i reset a zeepad
To reset your zeepad you must reload the firmware to it. For instructions go to
www.zeepad.net
Jul 17, 2012 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
ZEEPAD 7 inch Android 2.2 Tablet Logo
27 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
enterprise_tech
Level 1 Expert
 Russ Hill
Russ Hill
 Gary Gemmell
Gary Gemmell
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
