Question about Poulan Pro Chain Saw 46cc 20"
Gas line diagram for poulan 446 pro - Poulan Pro Chain Saw 46cc 20"
SOURCE: gas line diagram for poulan 2050 2.0 CI '97
Gas line diagram for poulan 2050 .
Posted on Oct 25, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan 295 Pro won't start. Changed gas and
I suspect the carburetor is full of remnants of the same fluids you found in the tank. If it was my saw I'd take it to the local Stihl dealer for an estimate to repair. I'd expect to pay $40 - 80 for a tune up and repair depending on how many fuel hoses must be replaced. HTH
Lou
Posted on Oct 28, 2009
dontbother10
  • 2220 Answers
SOURCE: I wish someone out there could draw me a diagram
You can find a typical fuel system and a couple of suggestions here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
An IPL for a Poulan PP210 can be found here:
http://www.ordertree.com/modelinfo/PWE/PP210-Gas-Saw/75.PP210-Gas-Saw.1.59.1.html
The small hose goes between the filter and carburetor and from the IPL the carburetor and primer.
The large hose between the primer and fuel tank (return).
Hose can be purchased at any chainsaw outlet, Inquire about how much hose they recommend. I have not found a good hose stretcher and I have been looking. Good luck with your project.
Lou
Posted on Jan 30, 2010
  • 553 Answers
SOURCE: gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Posted on Jun 12, 2010
  • 30 Answers
SOURCE: I need a diagram of
Here http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006_545137250.pdf
Posted on Jun 13, 2011
Diagram of fuel lines poulan pro blower
Put your model number into goggle and search for a fuel line diagram and you should be able to find what you are looking for. Hope this helps.
Oct 03, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
Fuel line diagram poulan wild thing 40cc
I can't give you an actual diagram but a I can try to explain how it should go. There is a line with the filter in the tank that goes to the bottom of the carb, there is another line from the carb that goes to the in port of the primer bulb, the out side of the primer bulb will go back down into the fuel tank. The primer will pull gas from the tank through the carb into the bulb then return the gas from the bulb to the tank
Feb 01, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need a diagram of how to route the throttle line on my Poulan 225 Pro chainsaw. Where can I get one?
Jun 13, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Need a gas line diagram for a poulon pro ppb250E
i need a gas line diagram for a yamaha vmax it leaks gas all over
Sep 18, 2010 | Poulan Garden
Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Nov 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Gas line
What little fuel system detail ther is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Find a model number that matches your saw.
Fuel lines run from the tank to the carburetor to the purge pump and back to the tank. Take extensive notes and a few digital photos as you go are a good idea.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
HTH
Lou
Oct 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need a diagram of the fuel lines on a poulan 2150. what lines go where?
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP⟨=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
Apr 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro Chain Saw 46cc 20" Logo
140 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
