Question about GE Iti L/m Water Resistant Pendant Panic 60-578-10-95
NEED MANUAL FOR ge 60-578-10-95 iti PLEASE.
Itis a printing problem i see the ekg lines it says collecting analying and printing but doesnt print
hi,
If you can the QRS wave on its display for all the leads and if the machine is not prinding then the problem is with the printer side. First of all you have to check is the paper is inserted propely or not. If its ok then the motor or its driving section can becom faulty. Also there is one more chance is there the battery. If any of the cells in the battery is faulty then the machine will not get the proper voltage and fails to print. Its an 18V 1.4Ah battery. If you need the service manual for the machine then I'll sent the same. For that i need your email address. I can't upload that manual by fixya as it is in PDF format.
OK
OK
Sep 28, 2011 | Ge Medical Systems Ge Healthcare Mac 1200...
I want to change the dialing number on my allegro GE security system, part no. 60-874-95R. Can you help with this without the vendor's help? Thanks
Follow the instruction on the install manual, page 7. you should start by cleaning the memory of all the previous data - as explained in page 6.
If you don't have the manual get it from here
http://download.homesecuritystore.com/downloadmanual.aspx?FileName=ALLEGRO_Install.pdf
Sep 07, 2011 | Allegro Ge Iti Allegro 80-795 / 60-879-95r...
Hi, i'm using the Caddx NX4V2, the fire light flashes rapidly and no keys are working to stop it, i did read a manual that says the rapid flashing fire led means that there are problems ... how do i pin...
If you know the 'go' code ( default 9713 ), you can press *+90 to see the event log, which you scroll through with the arrow keys on the keypad (alpha keypads only). If that is not available, you will need to have a certified alarm installer come and check your system for faults.
Dec 13, 2010 | GE Iti Caddx Nx4 Control Panel 48 Zone...
Does not spin in spin cycle
If itis a GE, maybe motor not reversing (can be motor or switch that tells it to reverse). Can be transmission slipping ( this is more difficult to repair). Goodluck, Macgivor
Jan 16, 2010 | GE Washing Machines
I have a GE Range. Purchased in 1993. The user guide says it is for JSP26GP, JSP28GP, JSP31GP. The thing won't quit beeping and the function code displayed if F1. What should I do? Thanks!
The F1 error code means your oven temperature has exceeded 590 degrees and the beeping is to warn you to shut it off.
Itis likely that the oven thermostat has failed, so you will need to get it replaced.
Jan 04, 2010 | GE Ovens
Looking for technical manuals
I talked to 3 different departments at ITI, they all say you can't get them anymore (sales, tech support, and repair) No one even has a number for a refurb equipment company.
LINE CARRIER POWER TRANSFORMER
: : ITI part #60-145-235 Canada part #60-366
: : The power transformer supplies a DC voltage of approximately 13 to 14 VDC (unloaded) to the CPU through terminals 1 & 2. Additionally,it contains the line carrier circuitry for the Wireless Interior Siren through terminal 3. The AC power indicator voltage for the CPU is carried through terminal 4.
: : The Transformer is fused with a 400 mA fuse on the primary side of the transformer. Replace only with a 400 mA 250V Time Lag Fuse (ITI Part #33-023).
This is all I could locate, hope something here helps.
please leave rating. thank you
May 06, 2009 | Computers & Internet
Repair parts for simon 3
Try eBay. Look for any of the following keywords:
"GE Simon"
"ITI" (that's eye-tee-eye, for Interactive Technologies, Inc. original developer of Simon, now a subsidiary of GE Security)
"319.5" (the frequency on which simon sensors operate).
You'll find almost any sensor you can imagine there.
Feb 15, 2009 | GE Security Simon 3 Wireless Home Security...
Ge dishwasher gsd2200g02ww
There was never a problem. Sorry about that. It was a gasket off of a lid. Silly me.
Oct 06, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
GE Iti L/m  Water Resistant Pendant Panic 60-578-10-95 Logo
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
