I had problems with my monitor. I am purchasing a new monitor. When the new monitor is connected to the computer does the BIOS default setting adjust to the new monitor? I am just a computer user not, in any way beyond that.
  • 2,794 Answers
Sometimes the BIOS doesn't display properly on the widescreen monitors if your video card was built before widescreen monitors were acceptable. I have an old ATI Radeon video card from 2006 and it cuts off the BIOS setup screen when setup. If a 640 X 480 monitor was plugged it, the problem would go away. The graphic drivers aren't going to initialize in your computer until the computer is booted which compensate for the current resolution settings.
Another solution is to see if you have a BIOS upgrade available for your computer that will create a resolution and refresh rate that will work for your monitor.
Posted on Oct 13, 2013
3 Suggested Answers
  • 2678 Answers
SOURCE: Had to restore computer to factory defaults, now
Default monitor settings would suggest that you have not yet installed the drivers for your graphics card.
Right click on my computer, select properties then the hardware tab.
Check all drivers have been reinstalled.
Posted on Dec 16, 2009
Testimonial: "Thanks for you response. Already did this step; driver not loaded and doesn't exist on the CD monitor came with. Now trying to contact V7 for driver"
  • 1584 Answers
SOURCE: My company just purchased a user a View-sonic
It sounds like the HDD is set to hibernate.
Go into Control panel / Performance and maintenance / Power options and select all to "never"
Posted on Dec 23, 2009
I have an hp pavilion dv5. When I power it on the computer starts up but the monitor doesn't come on. And then it does this series of beeps. Beep beep beep. It does that series 5 times
Before you begin
Check the following items before using the steps in this document:
•If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
•Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
•If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
•Disconnect all connected devices except the mouse, keyboard and monitor. This includes thumb drives and camera-type memory cards from card reader slots.
With the devices disconnected, restart the computer. If the computer starts and the monitor now displays a picture, a device is preventing the computer from starting. Update the BIOS to resolve this issue.
Step 1: Connect the computer to another monitor
Connect another monitor to the computer to determine which device has the problem (the monitor or the computer). This step is very important to help you determine if the problem is coming from the computer or the monitor. If necessary, temporarily connect the computer to a friends monitor for troubleshooting purposes.
After the monitor is connected, turn on the computer and the monitor. What happens?
•If the newly attached monitor does not display anything , disconnect the cable and continue at Step 2: Is the video connection damaged?
•If the newly attached monitor displays the first startup screen(s) but then goes black, there is a problem with Windows starting. Skip to step 5 .
•If the new monitor works , the original monitor or its cables are faulty. Do the following:
1.Replace the monitor power cable.
1.Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
1.Replace the video cable.
1.If the monitor does not work after replacing the cables, replace or service the monitor.
Inspect the video cable and video connectors for damage. Check for sharp bends or breaks in the cable and bent or broken pins at the connectors. With the monitor and computer off, try to straighten bent pins with a small metal tube, like the tip of an empty mechanical pencil or the tip of a retracted pen.
Figure 1: Video connector
If you had to straighten any pins, reconnect the monitor making sure that the video cable is firmly connected and then turn on the computer and monitor. If the display is still blank, continue to the next step.
Step 3: Resetting and updating the BIOS
You can use these steps even though you will not be able to see anything on the monitor.
In case an item was changed in the BIOS, such as the primary display device setting, use the following steps to reset the BIOS back to its default configuration:
1.Turn on the computer and repeatedly press one of the following keyboard keys. Press the key about once every second for 5 seconds after turning the computer on.
◦For HP and Compaq computers that came with Windows 7 and Vista, press F10 .
◦For HP and Compaq computers that came with Windows XP, press F1 .
◦For Compaq Presario desktop computers built prior to 2002, press F10 .
1.Wait another 5 seconds.
1.Press the F5 key. This restores the default settings of the BIOS.
1.Press the Enter key. This accepts the changes.
1.Press the F10 key. This saves the changes.
1.Press the Enter key. This saves the changes and exits from the BIOS.
1.The monitor should display the first screens received from the computer (the logo screens). If not, find and download the latest BIOS update if one is available for your computer.
1.If a BIOS update was not available or the monitor is still blank, continue to the next step.
Jun 11, 2010 | Computers & Internet
When the monitor is switched on an orange light shows, no green light and screen says 'going to sleep'
your computer is not able to "see" the monitor. Try going into the BIOS settings when u first turn on the computer by pressing F1 or whatever key your computer uses to enter "SET UP". Then, select the F key that will "load default settings". Then, press F10 to "save and exit" and press enter to confirm. If that doesn't work, you either have a bad/incompatable monitor or a problem with connections or the video card or port.
Apr 28, 2010 | HP Pavilion F1523 15" LCD Monitor
Monitor won't come on..just blinks..
a common way to solve this is to put the BIOS into its defaults...
i.e, loading the BIOS with default settings..
to do this you need to open the case of your CPU then, on the motherboard there is a small battery called CMOS battery...
take it out and after a minute or so put it back...
in this one minute, the BIOS will get reset to its default settings...
you should now be able to work........
If this sol. helps please give a vote....
Feb 28, 2010 | Compaq Presario 1725 Monitor
Compaq pressario
Techguru2009: First thing disconnect the monitor and start your computer. Then connect the monitor, can you see your operating system? You need to check your bios settings for power save mode. you might need to reset the bios. You can open your case and remove the battery for ten minutes or if you can load the bios setup reset the default settings. Hope this helps.
Jan 24, 2009 | Computers & Internet
For some reason the monitor has gone blank connected to my tower
Go through your BIOS setup and choose 'Factory Defaults'  This will set the initial video to a low standard that will at least allow about any monitor to come on.
The second system may just happen to be feeding your monitor what it wants to see.
Dec 06, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
Compaq presario beeps but the monitor does not come on
If there is long beep it means you have problem in your memory.
  • To fix this type of problem, Remove RAM clean its connection point and place it again. If still problem then you should try new RAM.
Thanks
Iqbal
May 11, 2008 | Computers & Internet
Monitor on but not working properly
If you just built the computer..the motherboard will give you a warning that some hardware has changed. you have to connect your keyboard and go into the bios and make sure everything is right. To be safe select set to default factory settings , save and reboot the computer. This is to prevent the settings for a previous cpu be used for the new one.
Feb 24, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Monitor
hi the problem isnt in the screen its in your configuration in the bios or your OS go insdie the bios menu and choose the default option and save it good luck
Apr 02, 2006 | NEC LCD1915X (Black) 19 in. Flat Panel LCD...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
