Question about Poulan Pro Chain Saw 46cc 20"
How is gas line attached to a 446 pro carb.? - Poulan Pro Chain Saw 46cc 20"
  • Poulan Master
  • 7,482 Answers
how is gas line attached to a 446 pro carb.? - b7369226-9bf2-4373-920d-a537dcea10f0.gif
Hi Claude
Hope this helps you
Bud
Posted on Oct 12, 2013
Poulanproleafblower not primeing
Either your fuel is broken inside the tank or your carb is blocked up inside. Empty the fuel tank and look inside and see if you fuel inlet line has a little plastic or metal filter on the end. *(this is called a "clunk") The clunk keeps the fuel line in gas no matter which way you have the blower tilted. Chances are you will see the clunk just laying in the bottom of the tank with whats left of the fuel line still attached. If the fuel line and clunk are intact then your need to get a diagram of the carb and do a dissembly and cleaning. The carbs have tiny screen filters which jam up with debris and gelled fuel. So a rebuild kit with new filter would be a good thing to get if your carb is cruddy. You can look online at Poulanpro and see which kit you need to buy. They are 10-15 bucks usually. New fuel lines is also a good idea if you are going this deep into the unit. Be safe and good luck!
Aug 25, 2014 | Poulan Pro Gas BlowerVacuum ()
Replacefual lines
Just take apart the air cleaner and any other covers around the gas tank and carb. you will see the lines, remove one and notice how attached, if you can re-use clamp good, if not count how many needed, take line to ACE, Auto Zone, Discount Auto you get the picture, ask for and give them gas line and also ask for clamps needed.
That's it.... any questions feel free to ask...
Nov 28, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a toro super cycler gts 5 model 20475 6.0 engine i put new gas in it a new spark plug but if i loosen the gas bowl no gas come out and it wont start what could be wrong
Ensure fresh gas is in tank. Follow gas line from tank to carb. Have locking pliers ready to pinch off gas line or close gas line valve. Remove gas line from carb. observe gas flow to carb. Remove carb bowl from bottom of carb. Attach gas line to carb. Does gas flow to carb. Observe float, float down gas flows, float up no gas flow. If float is bad replace float assembly or carb. Remove float mounting pin and needle metering valve. Use a bread wrapper pealed back an inch so thin wire can clean out port of meter needle. Use wire to clean out center port. Observe bowl screw look for hole thru screw, clean out with wire if preset. Re-assemble carb. Clean replace air filter. Fill oil. 30w. Prime motor, pull rope 10 times to start. No start, replace carb.
Aug 02, 2013 | Snapper 20 HP Lawn Tractor 2690578
Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Nov 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Poulan pro lamn tractor will not start
Carb is most likely clogged from when the gas you had in it before gummed up. Take some carb cleaner and clean the heck out of the carb and everything will work just fine after that. I also recommend letting the carb cleaner sit for about 30 minutes before trying to start the machine
Jun 03, 2009 | Poulan Pro " Pro" Self Propelled Mower
Looking for the diagram for the gas tank for poulan pro trimmer PP325 SKU:952711457. All the parts fell apert inside the gas tank
You have two lines going into the tank, a small and a large one. The large one goes just inside the tank and connects to the top outlet just under the primer bulb. The smaller line has the fuel filter attached and lays on the bottom of the tank. The other end attaches to the lower outlet on the carb. Hope that explains it for you. Dwain
May 19, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Gas not getting to carb. Blew out all lines gas, new gas filter
fuel line cracked in shroud just fixed one just like it check fuel line from filter to carb
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Poulan Pro Chain Saw 46cc 20" Logo
87 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
