Question about Freezers
My fridge keeps freezing everything and the remperature reading isnt normal
  • Freezers Master
  • 7,482 Answers
Hi Whingo
Replace your defrost timer...it causes the problem you have stated
Bud
Posted on Oct 12, 2013
Fridge Freezes Everything
there is a motor with a flapper that opens and closes to keep your temp correct in the refrigerator side most likely the motor is bad and stuck open so your air from the freezer has constant flow to the refr side. the flapper is in the back of the refr behind a cover where the air flows in.
Apr 16, 2014 | Emerson Cr180 1. Cu. Ft Compact...
The edge of the wall between the freezer and fridge is very hot
This is normal. There is an electric, (mullion), heater behind that surface that keeps condensation from forming. It also keeps the freezer door gasket from freezing to the surface and ripping when the door is opened.
Jun 01, 2012 | Whirlpool Freezers
Freezes up in one week and has to be defrosted
It normally happens with older versions of refidgerators which is normal.
what you can do is try to keep the regulator of the fridge on medium freezing
Jun 04, 2011 | Frigidaire Freezers
Our chest freezer isn't keeping food on top frozen although the bottom is still frozen solid?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help in solving the problem....
Jan 11, 2011 | Freezers
Carpingani 161 wont freeze --plenty of gas in machine
if there is gas in it. no frost buid up and the evap coil isnt crested all the way across. then you have a blocked filter. your gage will give an inconsistant reading when the filter is blocked. may read normal but other times will give a higher or lower reading. try changing the filter. the other thing i see is the compressor maybe too weak for the freezed. very common that the manufacture has put a small compressor that may only work adequetly for a few years.
Aug 01, 2010 | Freezers
My freezer isnt as cold as it should be, top part of fridge isnt as cold and ice maker isnt freezing water
find the air vent and see if there is anything in front of them to prevent the air from recirculating. ice could be in the vents to,
Apr 13, 2010 | Freezers
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
50 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
