Question about Bosch Dryers
Bosch Maxx Sensitive won't start
I have a bosch maxx sensitive dryer, the anti crease/end light is flashing and it beeps (3 short beeps x 3 times). What seems to be the problem?
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: My new Bosch maxx 6
It could be something as simple as the water drawer is not properly in it's little compartment. Try repositioning it. This video shows how a dryer like yours works:
Posted on Dec 01, 2010
My bosch maxx 7 sensitive dryer is not working - no lights are lit up, door is closed, filter is clean, container is empty, just beeps twice when i pusch start
Well I would recheck the water reservoir is fully inserted ....the door has no debris inside the lock....the bottom filter is cleaned not just the door filter.if this still not fixes then try a reset by switching off at socket then whilst holding start button without releasing for at least five seconds turn on power and listen for a click.sometimes a sensor is stuck and not relaying proper status.
Feb 22, 2015 | Bosch Dryers
I have a Bosch Maxx 8 sensitive drier and it sometimes will not start but if it does it will stop and reset the clock and sit there waiting like its at the beginning like you haven't done anything!
any service tech will tell you get a basic one without all the options, you'll be happier, even the manufacturers dont know how to fix these yet
Feb 01, 2015 | Bosch Dryers
Bosch sensitive maxx dryer flooding
probaly your pump is faulty
Jan 28, 2014 | Dryers
I have a Bosch Maxx Sensitive WTE84100AU dryer which stops a few minutes after the dryer starts. The dryness lights all turn off. The clothes don't dry.
There is a thermal overload switch behind the back cover. It has overloaded because the big lumps of lint in a) lint basket, b) small vents either side of the vent basket (use a chopstick), c) in the big pull out condenser unit at the front bottom left, and d) reach right to the slot for the condenser unit and scrape all the lint out of the back.
Now you can do the reset - unplug your dryer first. You will need a Torx T15 screwdriver to undo the all screws around the fan & drum cover, then use a thin blade to pop off the back cover. If you don't have a Torx screwdriver, you will have to buy or borrow one - there are just too many screws to use anything else.
I was thinking of drilling a 6mm hole in about the right spot so I can poke a chopstick through to press the reset button. 6607f76a-b20b-43ef-8059-a4858d51d2dd.jpg
Jan 08, 2013 | Bosch Dryers
My dryer Bosch maxx 7 doesn't work
That is a bad motor. It is overheating and the overload is shutting it down. Check to see if there is lint buildup on the motor. If not, you will need a new motor.
Nov 04, 2012 | Dryers
Bosch logixx7 tumble dryer won't start. It just beeps and a key sign shows on the screen
Do you have to the control lock turned on? This sounds like the case
Jun 15, 2012 | Bosch Dryers
Bosch maxx dryer
The manual for our Maxx WTL6500 says to press and hold the Start/Stop button for 4 seconds. "The child safety lock can be released permanently using the Menu button." In our case that means press Menu 3 times then press Change to set the lock on or off.
HTH
Jul 02, 2008 | Bosch Axxis WTL 6307 Electric Dryer
Bosch Maxx 6 doesn't dry anymore?
Yes,it is the first thing to check ,If you can somehow see if its glowing when you start the dryer.It may also be a thermal fuse.
May 22, 2008 | Dryers
Dryers Logo
147 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
