Firewall code - Computers & Internet
Error 0x8007064c when installing windows live messenger on windows 7.
How to enable Windows Firewall when you receive an error code 0x80070643 or 0x800706d9 during Windows Live Essentials installation
Symptom:
Users are reporting installation issues when installing Windows Live Essentials.
You might receive one of the following error codes during the installation process: 0x800706d9, 0x80070643
Cause:
When Windows Firewall is disabled, installation of Windows Live Essentials could fail in some cases, because some Windows Live Essentials components require Windows Firewall to be enabled in order to install successfully.
Background information:
Windows Firewall is a software based solution to filter incoming and outgoing traffic of your computer or network. All traffic to and from your computer pass through Windows Firewall, which inspect all types of traffic and either allow or deny traffic depending upon the firewall settings. Microsoft includes the built-in firewall feature in all latest Windows operating systems like Windows XP, Windows Vista and Windows 7
Resolution Steps:
To enable Windows Firewall in Windows Vista/7 please follow the steps:
Note: To use this feature, you will need to be logged into your computer with administration rights.
1. Click on Start button and then click on Control Panel option.
2. In Control Panel click on System and Security link to go next.
3. Click on the link Windows Firewall
4. On left side panel, click on Turn Windows Firewall on or off
5. Select Turn on Windows Firewall for all (Domain, Home and Public network)
Jun 11, 2011 | Microsoft Computers & Internet
Error code:52230
Error Code: 52230 There appears to be an issue with your wireless router's firewall.
  1. It is possible that your Internet Service Provider (ISP) is not compatible with the Wii console. For instance, if you need to login with a user name and password when you try to go online for the first time after restrarting your PC, your ISP is likely not compatible. Please contact your service provider for more information.
  2. If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls, click here.
  3. Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
  4. If you are still receiving this error code, please click here for assistance.
Aug 18, 2010 | Nintendo Wii Console
I try to download my updates but code 646 keep coming up,how do i deal with this problem?
The problem is due to the firewall, turn off any third party firewall you are using and also turn off the Windows Firewall which is located in the Control Panel --> Windows Firewall
Jan 12, 2010 | Computers & Internet
I cannot connect to internet wireless.error code 52230
Have you tried disabling the firewall on your router. This error code is associated with this problem.
Jim
Dec 24, 2009 | Nintendo Wii Console
Keep geting error code 646 when trying to install updates
Hi ,
Disable windows firewall and try again
Type firewall.cpl in run command , then disable the firewall
Thanks
Siju.D
Nov 16, 2009 | Computers & Internet
How do i disable the firewall to enable updates? some updates won't install, error code seems to suggest a firewall may be stopping this, the router has a firewall and i think this may be causing the...
The router firewall should never be the cause of failing updates. If the update is detected and download, the installation can only fail because of local computer settings, not a router's firewall.
So your PC's firewall could (maybe) be the cause, but even that is not common.
What is the error message? And is this a Windows update or a specific program update?
Nov 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
81003005 plz help me?
Error code means your firewall is blocking it. It's not yahoo, it's your firewall settings on your own computer. Check your firewall settings.
Nov 11, 2009 | Yahoo Messenger
Code 646 when trying to update
You need to disable your firewall. If you’re using McAfee Personal Firewall, or Norton Internet Security or another Firewall vendor, see vendor support page for assistance in disabling it (temporarily).
If you’re using the built-in Vista Firewall, keep reading.
- Open the Control Panel and select Security.
-Select Turn Windows Firewall on or off.
- Select Off (not recommended), click Apply and then OK.
- Back at the Windows Update screen, click the Try again button.
-The download(s) and installation should start…
-And this time successfully install. Now make sure to re-enable your Firewall once your PC restarts.
* Though this solution will work for most Vista Update errors.
Oct 24, 2009 | HP Pavilion dv1000 Notebook
What is error code 52231 ? Can't connect ot internet.
That means your firewall is interfering with your Wii's connection.
Aug 03, 2009 | Nintendo Wii Console
Computers & Internet Logo
David Payne
David Payne
