Question about HP LaserJet 4 Plus C2037A Laser Printer 10MB PC 162732
Where is the laser scanner in a laserjet 4plue
  • 65 Answers
Hi.
The laser scanner is located under the top cover. You have to remove the top cover to reach it. 4 screws, one in each corner.
Remove the cartridge and disconnect power before you get to work. Remove top cover carefully. Watch out for small wires.
The laser scanner is a black plastic box, with a couple of wires connected to it. Good luck.
Posted on Oct 16, 2013
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
WHAT IS LASER WHAT IS SCANNER INSIDE HP LASERJET 5035
The scanner is a small mirror that rotates at high speed, allowing the laser beam to scan, hence the laser whining.
Feb 12, 2015 | HP Office Equipment & Supplies
HP LaserJet M1212nf MFP suddenly began printing all letters stacked on top of each other. Basically all stacked up on left margin
The problem is most likely with the laser scanning unit. Check for damage to Flat Flex. Cable between formatter PCB & laser Scanner unit. Checks the FFC ends for damages. Repair the ends / Replace FFC if required. Service or replace the laser scanner unit if problem persists.
Jul 25, 2014 | HP LaserJet Pro M1212nf MFP -...
Erroe corde 51.10
Note: Technical skills required:
Laser scanner error:
A. Reseat the connectors between the
laser/scanner and the dc controller PCA
(J801 and J321).
B.Make sure that the laser/scanner
cartridge door interlock mechanism is correctly functioning or not
C.Replace the laser/scanner assembly.
See
D.Replace DC controller.
Laser Scanner assm:
Apr 30, 2014 | HP LaserJet M5025 MFP Printer
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
A printer error has occurred.
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
assembly. Calibrate the printer after
replacing the laser/scanner.
Mar 17, 2014 | HP LaserJet 4650n Printer
Error 52.0
Hewlett Packard P3005 52.00 Error - Indicates a critical Laser Scanner error has occurred.
Loose cable connections or faulty laser scanner.
*** The Laser Scanner should only be accessed by qualified individuals. ***
Resolution - Power cycle the printer - if the error persists, change the scanner.
Part Number Laser/scanner assembly RM1-1521-030
www.partsnow.com
Dec 28, 2010 | HP LaserJet P3005 Printer
Error 51.10 hp laserjet p4015x
Laser/Scanner error. Go the the Diagnostics Menu. Run the Laser/Scanner motor component test.Make sure that you can hear the motor rotate. If the error persists replace the Laser/Scanner assembly
Sep 07, 2010 | HP Laserjet P4015x Printer
Hp laserjet 3055 has code 52 scanner error and wont print or copy
PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Jan 15, 2010 | HP LaserJet 3055 All-In-One Printer
My printer shows 41.2 errors
Hope it helps
1. A temporary printing error has occurred.
2. Press GO. The page containing the error will automatically be reprinted.
3. Reseat the connections to the laser scanner and then to the engine controller board.
4. Replace the laser scanner.
5. Replace the engine controller board.
Jul 08, 2009 | HP LaserJet 4100 Printer
HP LaserJet 4 Plus C2037A Laser Printer 10MB PC 162732 Logo
24 people viewed this question
Seeker5211
Seeker5211
