Question about Baumatic MEGA6SS Front Load Washer
Powder still in drawer at end of wash - Baumatic MEGA6SS Front Load Washer
Detergent left in dispensing drawer on lg f1402fds6
actuator valve may need replacing that lets water into compartment.
Jan 09, 2016 | LG F1402FDS6 Front Load Washer
Water leaks out of the washing powder compartment
it might from closing the powder drawer not completely and correctly
or having crack in the drawer
or having the high water pressure in the Water pipeline network
check all above , if not , call service center
thank you
Nov 05, 2014 | Beko Wm & Wma Models Washing Machine Motor...
How do you use the tub clean?
Read these instructions carefully before
beginning the TUB CLEAN cycle.
Open the door and remove any clothing in
the wash drum.
Open the dispenser drawer.
Add liquid chlorine bleach or tub cleaner.
Some powder or tablet tub cleaners which
are manufactured for this purpose can be
used.
(NOTE : Do not add any laundry detergent
or fabric softener to the drawer when using
TUB CLEAN.)
- If using liquid chlorine bleach
Add liquid chlorine bleach to the bleach
compartment of the drawer.
(NOTE : Do not exceed the maximum
fill line and do not pour undiluted liquid
bleach directly into the wash drum.)
- If using powder cleaner
Remove the liquid detergent cup and
add powder cleaner to the main wash
- If using tablet cleaner
Add tablet cleaner to the wash drum
directly.
(NOTE : Do not add tablet cleaner to the
drawer.)
Close the drawer and washer door.
5
Select TUB CLEAN and press START.
NOTE : It is recommended that TUB CLEAN
should be repeated monthly.
If mildew or musty smell already exists, run TUB
CLEAN for 3 consecutive weeks.
After TUB CLEAN is complete or when the washer
is not used, leave the washer door open for better
ventilation and drying inside of the washer
Jul 05, 2014 | LG WM2701HV Washer
The washing powder is still in the dispenser at the end of the full wash??
See if the water is actually running into the washing powder tray by using these guidance notes (written for another problem!).
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
Now if the water is NOT pouring into the washing powder tray an engineer call is required ;-0(
Good luck,
John C
Mar 29, 2011 | Whirlpool AWOE8748 Front Load Washer
The fabric softener drawer on my hotpoint hd420 is not draining. At the end of a wash the fabric softener drawer remains for of water. Can you advise?
It is not that unusual to find some plain water remaining- has the softener gone OK?
If not here is just a quick POSSIBLE (1st) solution if you have not tried it already-
Completely slide out the drawer - normally made possible by pressing down the plastic flap at the backend of the softener part of the drawer - as it is normally in the middle.
You may find 'gunge' made up of washing powder (if you use powder of course!) and softener combined in the tube that the softener should syphon into. Wash out with plenty of water!
I do this to ours fairly frequently.
Hope this helps.
Jan 22, 2011 | Washing Machines
Washing powder clogs up in drawer
There should be an adjustable "barrier" in the drawer. One for liquid and one for powder. Open the drawer and look at it carefully, you may need a flashlight. See where you pour the powder in? Well... you know what they say about pictures and a thousand words...
Since I don't have your model number, yours will probably look different than this pic,, but it should be close enough. All you have to do is set the barrier to the "Powder" setting.
SG
Mar 26, 2009 | Washing Machines
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
My machine is pumping water out the dispenser door what could be wrong
if you mean that water is coming out via the drawer that you put the powder then:
The powder has become solid in the drawer and blocked off the pipe leading to the drum.
What you need to do is to get boiling water and pour it into the detergant and using the pointy end of a wooden spoon break the sludge free in the pipe and the detergant draw.
Please leave feedback
Aug 02, 2008 | Washing Machines
Baumatic MEGA6SS Front Load Washer Logo
13 people viewed this question
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
