Question about Water Heaters
Ge Wiring Diagram for a cat.# 34021 fan that has a brass blade
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
Ge wiring diagram
see if you can remove back panel and push it back through hole. fasten it so you wont lose it again.
May 13, 2014 | Water Heaters
GeoSpring GEH50DNSRSA wire diagram
Here are all the resources that are available for GE heat pump without calling GE and hearing them tell you to call service technician:
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
There is no wiring diagram for the bundles of wires coming from chip control board.
As general rule, these things are made to last 10 years, and afterwards will not function or be repairable. It's like a window air conditioner, except connected to water pipes, and connected to computer chip and multiple sensors, each susceptible to failure, and then the machine is used 24 hours a day, 365.
Designs have changed continually from 2009 to 2010 to 2012 models.
It's likely you got a nice piece of junk with depleted anode rod and failed sensors that stopped working and somebody got rid of it because it wasn't repairable.
http://waterheatertimer.org/How-to-recycle-water-heater.html
Add a comment
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 02, 2013 | Reliance & 40 Gal Electric Mobile Home...
GE Water Heater, Calrod, failed after power outage
Check the power is good to the heater then check there is power on the elements. That will tell you exactly where the fault lies.
Feb 01, 2018 | General Electric Water Heaters
I need a wiring diagram for a ge 240 vac timer please
GE sells several timers rated for 240Volts.
Including the 15307 timer made by Tork, rated 208-277Volts, 40 amp, 60 Hz
Copy following link for wiring GE 240Volt timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Oct 18, 2012 | GE 15307 240 VAC 24-Hour Outdoor...
How do I reverse the direction that my condenser fan is blowing?
You would have to replace the fan blade with one with the opposite pitch. In other words a fan that is a mirror image of the one in place. You cannot reverse the flow by flipping the fan blades over.
Why do you want to reverse the direction? I can think of no benefit in doing so. But then again you posted this under a Water Filtration heading?
Jul 17, 2009 | General Electric GE SmartWater Household...
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
