Question about HP LaserJet 4 plus Printer
My hp 4 laser has a error code 51 - HP LaserJet 4 plus Printer
  • 85 Answers
Reseat cables to the laser/ scanner and engine controller
Replace the laser/scanner
Replace the DC controller.
Posted on Nov 02, 2013
3 Suggested Answers
  • 39 Answers
SOURCE: I have error code 51 and 21 on the printer. I
21 is "Page too complex"
51 is "Beam detect error" or "laser error"
My question to you is, does this only happen when you are printing a page that is very graphics intensive, or does it happen with simple jobs too? It could be that you just don't have enough memory in the printer to handle some of these pages. Then again, you may have to replace the laser scanner. I advise you to call a tech out to take a look at it rather than trying to fix this on your own.
If it isn't happening too often I'd probably just **** it up and live with it if it were me. If it is getting in the way of business though you really ought to call a tech. A lot of times these things can be fixed for a lot less $ than you'd think.
Posted on Dec 22, 2009
seeker5211
  • 1089 Answers
SOURCE: HP Laser Jet 4 Plus error code 52
A 52 error is a Scanner failure. Do you hear a "whirring" sound when you get the error?
That's the sound of the scanner motor running amuck.
You're probably going to have to replace the Laser/Scanner assembly or the DC Controller which controls the Laser/scanner motor.
Posted on Jan 23, 2010
Error code 51.23
From the HP manual.
51.XX Error, Turn off then on
Description
The product has experienced an internal hardware error.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product on.
If the message persists contact HP support.
From PrinterTechs.com
51.X PRINTER ERROR
A loss of beam-detect occurred. X description: 1 = Beam-detect error 2 = Laser error
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
Oct 08, 2016 | HP LaserJet Pro 400 color M451dn - Printer...
I have a HP Laserjet 4100N with an error code 51.2. What part do I need and is it something I can do myself after receiving the part?
http://www.printertechs.com/printer-troubleshooting/401-51-01-51-1-error-hp-laserjet-4100-laser-scanner-failure
Jun 28, 2016 | HP LaserJet 4100n Printer
51 error code
That's a "beam detect" error. You probably have to get the laser/scanner replaced. Part Number C2037-69008.
Jul 16, 2014 | HP LaserJet 4 plus Printer
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
A printer error has occurred.
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
assembly. Calibrate the printer after
replacing the laser/scanner.
Mar 17, 2014 | HP LaserJet 4650n Printer
51.10 error
Thank you for contacting FixYa. I have been working on some archieved inquiries that may have gone unanswered. Your issue is a beam detect error with your laser scanner.
HP LASER PRINTERS 4200, 4300, 4250, 4350 ERROR 51.XX
1. Printer has a beam detect error
2. Replace the cable ***'y from scanner to D.C. controller
3. Replace the scanner ***'y
4. Replace the D.C. controller.
Aug 25, 2011 | HP LaserJet 4350 Printer
The printer is showing error 51 and not printing
Control Panel message
51 PRINTER ERROR
Description
Beam error
Action
Laser scanner cable connectors are faulty or laser scanner assembly is defective Most likly it is the laser/scanner assembly. The motor is probably not spinning at the right speed. You would need to find an old hp 4 no longer working and switch the laser/scanner. It is the "black box" located under the top cover. You would need to remove the right side cover, the top cover, the left side cover and the output assembly. Remove all the cables from the scanner retaining clips. Remove the three cables plugged into the scanner and remove the four screws attaching the scanner to the frame. When replacing the scanner make sure the shutter control arm on the left front side of the scanner is attached correctly so that the shutter closes when the toner cartiridge is removed. You could first try to remove the 3 connnectors and reset them.
Nov 17, 2010 | HP LaserJet 4 plus Printer
An error code of 51.10 has been popping up all day for my p4014n printer. Help!
Try this site:
http://www.printertechs.com/tech/error-codes/error-codes-50-59.php
" 51.X PRINTER ERROR A loss of beam-detect occurred. X description: 1 = Beam-detect error 2 = Laser error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
Mar 09, 2010 | HP LaserJet P4014n Printer
HP Color LaserJet 2605dn_2605dtn error code 51.22
The 51.xx error occurs when there is an error in connection with the laser, if you open the printer to clean the lens, surely you have forgotten to replace the cable connection purple laser. open it again and reconnect all cables OR: 51.X PRINTER ERROR A loss of beam-detect occurred. X description: 1 = Beam-detect error 2 = Laser error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
Mar 06, 2010 | HP LaserJet 2605DTN Color Printer
Error 51.1 HP 4100
Error 51.X is a loss of beam-detect occurred.Possible reasons:
1 - Beam-detect error
2 - Laser error
Oct 22, 2009 | HP LaserJet 4100tn Printer
Error 51 HP 4Plus laserjet printer just stopped and error 51 appeared cartridge replaced replaced repair kit
Hello sir; 51 often in this model, change laser assembly( C2037-69008 ). next tryDC controller ( C2037-69004 ).
Mar 08, 2009 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
Seeker5211
Seeker5211
