Question about Craftsman Garden
Craftsman mower moves slowly
I can put the mower up on blocks and the wheels look like they are moving fine but once on the ground, it only moves very slowly?
  • 205 Answers
SOURCE: Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
yes
no
Posted on Mar 21, 2009
  • 376 Answers
SOURCE: Craftsman 19hp won't move when in gear
There is a square key about 2 " long that fits in the slot on the axle and wheel and locks them together.. You probably didn't see it when putting tire back on and knocked it out. If you go back where you removed tire, you'll find it laying on the ground.
Posted on May 27, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Posted on Jun 08, 2009
GM Elec
  • 1000 Answers
SOURCE: mower stopped moving
If this is a manual transmission, check the drive belt from the engine back to the transmission. With the clutch pedal up (engaged) there should be no slack in the belt.
If it is a hydrostatic drive, check the drive belt and make sure it is tight. Check the transmission fluid level and make sure it is full. Refer to your owners manual as it will describe the fluid check proceedure.
Good luck, let me know.
Regards,
Posted on Jul 14, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
Why my craftsman rotary lawn mower back wheel do not move on the ground only air in the air?
Check belt diagram instal that belt is on correct, diagram should be under right foot plate
May 13, 2015 | Craftsman Garden
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
Craftsman mower #247.887760 rear drive. rear wheels lock-up when you try to pull mower backwards
The rear wheels are locked to the drive train. To pull or push the mower, you must pull out the release probably at the back of the mower, near the transmission.
Gary
Jul 10, 2011 | Craftsman Garden
I have a crafstman riding mower. None of the
check drive belt probably slipping /stretched out and needs replacement
Apr 08, 2010 | Craftsman Garden
Sears ZT 7000 mower, engine runs, mower will not move
Same problem. The drive belt pulley tensioner spring broke. Replaced and everything worked great.
Apr 03, 2010 | Craftsman Garden
Replaced my rear wheel now my lawn mower does not move.
when you removed the wheel be sure you have put the keystock back in the slot cut in the wheel and the axle shaft in each wheel if you had both off
put the wheel on the axle shaft and align the slots and insert the key stock once the slots are aligned with the axle and wheel.
insert by hand or tap lightly with a hammer and insert the keystock far enough to reinstall the axles e-clip
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 13.5 HP 30inch deck mower that wont driveright
Check the braking mechanism sometimes this will get stuck the clutch cable will be attached to it on the transmission, belt could be getting old and loose, an idler puller could be seized up
Aug 06, 2017 | Craftsman Garden
May 27, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
109 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
