Question about KitchenAid KSU90S0MLL 16" Undermount Stainless Steel Sink
We lost the plug to turn on disposal. How can I turn it on?
    Sergeant:
  • 268 Answers
Make sure the circuit breaker is off. Then you have to repair the outlet or replace it with new one. That is the easiest thing unless you toasted the outlet wiring that would require an electrician to fix. Lowe's or Home Depot have free classes on repair that.
Posted on May 01, 2014
Why my disposal won't turn off
Sounds like the disposal is plugged into the wrong outlet. Try moving to the other socket on the wall plate.
Aug 20, 2014 | Garbage Disposals
Garbage disposal is clogged
Does the other side of the sink drain? Are you sure it's the disposal thats plugged? If the disposal is plugged you can turn it on and plunge it a few times and see if that makes a difference.
Jul 07, 2013 | Garbage Disposals
Our 1HP Kitchenaid batch disposal does not turn off when the metal plug is removed. It runs for several minutes on it's own.
Replace disposal
Copy following link to repair, troubleshoot and replace disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Add a comment as needed, or repost question with detail
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 29, 2011 | KitchenAid Batch Feed Garbage Disposal...
DW just installed. Water doesn't drain when cycle is finished.
is this brand new ? if so check where the D/W drains...it should drain into sink through disposal or sink drain adapter ..was the plug removed from the disposal ?for the dishwasher to drain ?remove drain hose from disposal or sink adapter.put in bucket turn on to see if it drains ..if so remove the plug from disposal or clear debri from hose or disposal /drain adapter..let me know..good luck/joe/
Aug 28, 2010 | Bosch Evolution 800 SHE58C05UC Stainless...
When I insert the cover control stopper and turn, I can feel that the magnetic pull but the unit fails to start. Please help.
Make sure that the disposal is plugged all the way in the receptacle. Make sure there is not a circuit breaker tripped in your Breaker Box. There is usually an overload button on the disposal. Try to find it and press it. If the disposal has something in it that keeps it from turning the overload will pop out. If, when you turn it on again, it sounds like it wants to start but doesn't and the overload pops out again, then UNPLUG the disposer and try to get whatever is in it out of it. Then plug it back in and try it again. Best of Luck
Mar 08, 2010 | Now Evolution In-Sink-Erator COVER CONTROL...
The motor on my Badger 5 disposal was humming but not rotating. I cleaned out all the debris, reset it and now there's nothing - no hum, nothing. Is my badger dead?
The badger 5 has a dislodge device on the bottom right in the very center. An allen wrench will fit if you have lost the tool that came with it.
FIrts you will need to dislodge anything preventing it from turning. (Insert the right size allen wrench and turn both directions) The remove whatever comes loose after dislodging.
Then opush the red reset button on the bottom. Check the breaker that powers up the disposal, as you may have tripped it.
If the breaker is on, the unit is turning freely, and the reset button is pushed, then the next step is to check for power using a volt meter, to make sure the disposal is indeed getting power. If all the above has been done, the unit IS getting power then yes, the disposal needs to be replaced.
Oct 11, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Garbage disposal wont work
I'm going to ask a dumb question first. You didn't by any chance leave the plug in the disposer did you? I didn't think so but I had to ask.
Next I would check the "red" reset button on the side ot bottom of the disposer, reset it by pushing hard it should "click".
If this doesn't work look under the disposer and see if the is a allen wrench opening in the middle of the disposer, if there is get the proper size wrench (sometimes they are included with the disposer) insert it an turn the disposer counter clock wise, if this turns freely, the next step wold be to call the man.
Feb 15, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Switch will not turn on disposal
under the sink you will probably find an electrical outlet with the disposal cord plugged in. If so, plug another item into the outlet like a blow dryer to be sure you have power to the outlet. If you have no power the problem is a tripped breaker or a blown fuse. First check all of the plugs in the kitchen area including under the sink to determine if you have a ground fault circuit interrupter outlet. If you do, it may be tripped. If it is tripped simply reset it.
If you know you have power to the disposal then check to be sure no spoon or other hard object isn't in the disposal preventing it from operating. Use a flash light to check this. If there is no obstruction look on the case of the disposal for a reset button. good luck.
Jan 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I am attempting to install a dishwasher drain line to a kitchenaid disposal under my sink. The disposal is a Kadette 250 1/2 hp. There is some kind of block or plug stoping the water from entering the...
Remove the hose from the disposal, take a hammer and long screw driver, put it in the hole where the hose attaches and knock the plug out. Turn power off to the disposer and pull the plug out of the disposer. Hope this helps.
Aug 09, 2008 | KitchenAid Dishwashers
How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Apr 07, 2008 | Frigidaire 24 in. PLD2850 Built-in...
KitchenAid KSU90S0MLL 16" Undermount Stainless Steel Sink Logo
48 people viewed this question
Top KitchenAid Home Experts
john h
Tom Chichester
Are you a KitchenAid Home Expert? Answer questions, earn points and help others
