How to Drain water out of glass tube thats full
How to drain water out of the glass tube on a hb smith boiler.the tube is full to the top. I think its supposed to be at the halfway mark isnt it.
    Novelist:
  • 189 Answers
You do not need to drain the tube. Drain the "boiler" untill the water level in the tube is at the half way mark. If it keeps rising to high you may need to replace or repair your auto feed control. BOILERS CAN BE DANGEROUS IF YOU ARE NOT QUALIFIED TO SERVICE IT. You would be better off to hire a contractor to make the repair and to teach you the basic operating info on your particular system. You are better off spending the money for the repair SO YOU STAY SAFE
Posted on Apr 23, 2009
Even though the water well is full to the right level the machine does not detect this and flashes 'Add Water' then stops. Was working fine the day before. I suspect the water level detector switch is...
Tube for pressure switch sits outside drum and needs air pressure to activate the switch.you may find the water has entered the tube thus reducing the effective air pressure required to activate water level indicator.simply take top off washer and locate the tube , drain the machine via the drain tube near the penny trap before pulling off the rubber hose which comes from bottom of drum and drain out any water from tube, reconnect tube and the air that is now in the tube will compress as the water level rises to the point where it activates the switch.if still not fixed maybe need to replace pressure switch which is obtainable off eBay from various online sellers.
Jan 13, 2015 | Refrigerators
Leaks
The fitting at the top need to be looked at. Use tolit paper wipe around all the fittings and drain lines over head check the popoff valve next if you got a plastic drain valve. Replace it with a 3/4 nipple and cap or a ball valve full port and hose adapter turn gas valve off and use up the hot water I had a valve break during replasment cool water is better. Use pipedope on fitings
Apr 12, 2014 | AO Smith ECT-52 50 Gallon ProMax...
Frt18hs6dw9 top freezer refrigator
I believe it would be the defrost drain from the freezer is clogged. remove 4 screws in Refrigerator section which hold light bulb, temp sensor assy, etc.
there is a drain pan built in to the rear of this unit, and a tube which goes from the pan to the base of fridge. be removing the unit, you will be able to see if the drain pan has clogged, or if you need to carefully snake the drain tube.
Our unit the pan clogs every couple years.
Jul 08, 2012 | Frigidaire Refrigerators
I HAVE A WATER ONLY BOILER MODEL WR11E IT IS ONLY 6 MONTHS OLD AND THE PROBLEM IS THE WATER IS ONLY LUKE WARM AND NOT HOT AS IT WAS BEFORE
Turn the boiler off. Connect a garden hose to the drain bib. Shut the water supply valve off.
Open the drain bib and drain boiler. Close drain bib and open supply valve.
When boiler is full, go to the farthest faucet and open the hot water and let run.
Go back to supply valve and turn off and on a couple of times rapidly this will "bounce" sediment loose.
Repeat above twice.
Nov 08, 2010 | Heating & Cooling
Water in bottom of fridge
In the back of the fridge way down low on the very bottom you will see the tube. If you think it is clogged. Take a spray bottle filled with very hot water and just a cap full of bleach. Spray it on the drain hole and this will rsolve your blockage issue
Feb 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
DU943PWK won't drain
If you take the bottom panel off the DW, there is a white plastic tube that is sticking out, but attached to the motor. Turn the tube counter clockwise ( Please be sure to have wet vac ready as this tube will let water out, even if you think you have all water out, still have wet vac and towels ready) Pieces of things get stuck in that tube and make it hard to drain.. replace tube to motor after cleaning and test unit
Jan 10, 2009 | Whirlpool 24 in. DU900PCD Built-in...
WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Dec 20, 2008 | Whirlpool 19.8 cu. ft. Side-by-Side...
When I pull the lever to make an espresso it takes about 10 seconds for water to come out. It's as though all the water in the boiler (or heat exchanger?) drains out when I dont use the machine for about...
Tank fills automatically with level electrode on top of boiler. Same punp that brews your coffee will top up the tank. Electrode full of scale - no water in tank. The boppom of group has drain exit. Fully normal to have a bit water to drain out. tale apart and clean manually! Nothing to be afraid of. take photos as it can get tricky to get all pcs back after mayor overhaul. Larger commercial machines have the drain outlet covered behind a vertical wall. You don't see the water but the E61 group is identical!! ///Olev
Nov 01, 2008 | ECM Giotto Espresso Machine
Frigidaire FRT18IL6D
Hi thanks for your question. to unclog. pull fridge away from the wall. remove back cover , clean all coils. let fridge thaw for at least 24 hrs. get small plastic hose to push up the drain tube from the back. blow up yhr drain tube to clear the tube. thanks the appliance doc. please rte my answer, thanks.
Oct 12, 2008 | Frigidaire FRT18B4A Top Freezer...
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
