Question about HP Photosmart C7280 Laser Printer
Ink system failure on hp photosmart d7263 - HP Photosmart C7280 Laser Printer
SOURCE: HP photosmart C6150 all-in-one error
Been on an online chat with HP in INDIA for over an hour. Given that you would "think" the error might have to do with the inside or "ink" you would think they would have me open the machine. If there is enough room you've got to read this online chat. WORTHLESS and I will never buy another HP printer ever again. This All-in-one was 372 days old and for them to not even consider going inside but to immediately tell me to buy another one. I hope you can see all of this. If not email me at SusanVette [at] ya hoo dot com and I will share it with you. Doesn't all fit so here is their bottom line:
Sequoia: I wish to inform you that HP is providing an option to exchange this defective unit with a new released All-in-One unit.
Susan : How much?
Sequoia: Let me also explain the complete process in detail so you can pick the model that suits your requirement.
Sequoia: You can upgrade the defective printer for a upgraded printer. Under the upgrade option, you have the option of buying a upgraded printer at much lower prices.
Sequoia: It means, we will send you with the another printer with a minimal cost (which is equivalent to the service charges for repairing your defective printer) then we will take your defective printer.
Sequoia: Moreover, the shippment charges will be borne by us.
Sequoia: Would you be interested in looking at these options?
Susan : yes how much
Sequoia: We have HP Photosmart C7280 All-in-One Printer, Fax, Scanner, Copier.
Sequoia: You can use the same cartridges with this model.
Sequoia: The features of this model are:
• Built-in wireless and Ethernet connectivity
• Easy two-sided printing
Sequoia: The Actual price of this All-in-One is $299.99 *
Sequoia: However, under upgrade option HP is offering for $157.99
Susan : how do I proceed when i am ready as I want to read all the reviews on that particular model
Sequoia: I am afraid this offer is not applicable in hpshopping.com or from stores, as this offer is only applicable online from us.
Sequoia: If you would like to go ahead I shall arrange a call back for you so that you can order the printer directly from our call back team.
YADA YADA YADA... Write me at above email for full chat.
Posted on Sep 03, 2008
covertgreywo
SOURCE: Ink System Failure (Error 0xc05d1381)
Don't waste your time on the copy and paste HP solution above.
If you really want to fix your printer:
Okay, HERE IS THE ACTUAL FIX FOR THIS ERROR.
1. Disconnect your USB cable.
2. Turn off the printer.
3. Press and hold down these four buttons at the same time:
OK, Cancel, Black, Color.
4. While still holding them down hit the power button once.
5. It will Blink.
5. Hit the power button again.
6. Continue holding until you get a message on the screen.
7. Allow the printer to sequence through and there you go.
Enjoy.
Posted on May 01, 2009
SOURCE: HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Jul 11, 2009
SOURCE: Ink System Failure HP C5180
-------solution 1---------
HP C5180
Hidden tech menu For resetting and repair, FIX UIAUX
Fixes error 0xc18a0507 error ink system fail
press <left arrow> then press <setup> button together
then press <ok>once support R0631m comes on screen
right arrow 2 times to the System configuration menu
then <ok>
then <ok> to select and ok to confirm reset error.
then <cancel> to escape ( all of witch are onscreen instructions.)
presto restart and no further error
http://www.thecomshack.com/hpc7180.htm
------------- solution 2 ----------------------------------
HP C5180 All-In-One Printer HARD RESET:
Hold down HELP + OK button and unplug printer
Hold down HELP + OK button again as you plug the printer back in.
Then power it on, if it doesn’t power on automatically.
Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
Now you can release the buttons and simply power it back on.
I got an error message about “improper shut down” since I unplugged it w/out powering down. After I clicked “OK” the printer was just fine and didn’t mind anymore. And now I can print.
Posted on Sep 21, 2009
  • 3 Answers
SOURCE: hp photosmart 3200 all in one ink system failure
I know this sounds crazy but I did this and others have too, it worked. Hold down four buttons at the same time ( OK, Cancel, Black , Color ) and turn the power off. Note: I figured out how to hold the 4 keys down with one hand and push the on/off switch at the same time. Once you power the printer back up is will take a few minutes to go through maintenance. Then it will “hopefully” go back to normal. I did this 2x’s. HP gives you a procedure that doesn't work! They just want to make money off fixing it every 6 months. They are in the service, repair and “ink business” not printer manufacturing.
Posted on Feb 06, 2010
My HP Photosmart C7283 All-in-One printer has an error message: 0xc18a0306. Ink System Failure?
My HP Photosmart C7283 All-in-One printer has an error message: 0xc18a0105. Ink System Failure?
May 04, 2011 | HP PhotoSmart 1215 InkJet Printer
What to do hp photosmart c1580 series ink system
hat to do hp photosmart c1580 series ink system failure Oxc18a0001
May 01, 2010 | HP Photosmart C6280 Printer
HP Photosmart C6180 0xc19a0035 ink system failure message. Tried solution posted on this site. problem reoccurs. Anything else to suggest?
Go to http://www.ccl-la.com/blog and search for HP Photosmart. They have two protocols for clearing ink system failure errors. One resets the machine and the other re-primes ink through the lines.
Mar 13, 2010 | HP Photosmart C7180 All-In-One InkJet...
My hp photosmart d7263 shows an error"0xc18axxxx " on display.
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Feb 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure on HP Photosmart c5180
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP photosmart 6188 Ink Failiure System
Not sure how to help you. Ink failure I would think is cartridge failure. Are you original virgin cartridges or refills? I need the actual error message that the printer is giving.
Nov 14, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart 8250 Ink System Failure,error code Oxc18a0007. I've tried HP site for solutions with no success. Also tried re-installing software,replacing ink (all genuine HP) but no luck!
Jun 17, 2008 | HP - HP Photosmart 8250 printer
HP Photosmart C7280 Laser Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
