Question about HP Color LaserJet 3500 Printer
HP Color Laserjet 3500 printer - no black on left side of page
Prints well, except that the left side of each page is devoid of black. The right side is excellent black and color. Color is good on entire page, but there is a fade from the good right side black to no black on the left. There is no paper blocking the image, and I've substituted known good black cartridge and ITB from working CLJ 3500 printers in the building, same problem exists. Replaced the image drive assembly, RK2-0248-000CN, and added the washer to the shaft that HP recommends to prevent rattling or noisy black developer clutch sounds, XD1-1108-229CN while I was in there. Did a cold reset, and ran calibration. Still no black on left side. Any advice would be greatly appreciated.
  • 2 more comments
  • Nan Douglas Oct 01, 2007
    Thank you for replying. Yes, I've checked and cleaned the laser/scanner although I saw no toner on it. It's in the heart of the printer so it took some time to access and remove. I have a service manual from HP, and have replaced the electromagnetic clutch referred to as the developing engaging drive unit with no resulting improvement. During a print-stop test, a perfect image appears on the image drum of each toner cartridge (including black) but the black image does not transfer to the left side of the transfer belt, although all the colors do. No black is on the left side of the page but colors are. Still, the right side of the page is ideal with full color. Please tell me what part name(s) the developing unit consists of that you recommend replacing?
  • Nan Douglas Oct 02, 2007
    I looked at the Web page you have given me the link to, showing the transfer roller and surrounding parts. I pulled the transfer roller out of this printer and put in a transfer roller from a working printer of the same model, and nothing changed. I'm sorry I don't understand what the dev unit is you are recommending to replace? Is there a part number? Thanks.
    You're quite correct that it's a "single-pass" inline process on these printers instead of the carousel, and the image drum is contained inside each toner cartridge. I did run "Calibrate Now" 4 times, as a forum suggested, and the image is ideal on each of the image drums of the toner cartridges. The calibration pages have color across each page (except black is only on the right side of the black calibration page) but the color coverage is wavy on the left side of the magenta, cyan and yellow calibration pages, like a "watery surface" appearance. I will go back to the school and check all the contacts I can see inside, as you suggest. Thank you for the diagrams. I will try to enlarge them for better viewing. My email address is [email protected] and I again thank you for your generous assistance and information.
  • Nan Douglas Nov 06, 2007
    Just thought I would report what repaired this problem of no printing black on the left side of each page. I called HP and paid for the $39 repair assistance. The lady at HP walked me through all the things we have been through in attempting to get the black to print on the left side of the paper. Nothing worked until she suggested I put a folded up piece of paper in the top of the door above the transfer unit. It wouldn't stay closed with the folded up paper there, so I held it closed while it printed - and there was a faint showing of black on the left side, finally. Still we couldn't get it full black printing on the left.
    So the next morning I tried folding up four pieces of paper into fourths, which was 16 layers of regular, plain paper, and putting the "pad" of folder paper taped down in the cavity of the door beneath the transfer kit to press the transfer belt into the image drums of the toner cartridges. That worked. We now have full printing on the entire page.
    When I phoned HP back to explain that was the fix - to put in a pad of paper that would press in on the transfer belt, they offered a door assembly that would fix this problem more professionally, for $15 from HP, part #RC1-1574-000CN - Front Cover Assembly. I have not purchased that part due to the fact that the printer is working so well and I've spent so much time trying to find an answer, so I'll just leave it alone since the users are very happy to finally have their color printer working. Thank you to all who tried to help me.
  • 3 Answers
The folded paper solution for for me. Thanks to all for sharing!!!!
I had the same problem. No black or cyan on the left side of the pages. From this advice... I folded a stack of 4 pieces of paper in half and then half again. I took out the transfer unit and put the folded paper in the upper left corner and then put the transfer unit back in. WORKS BEAUTIFULLY! Thanks you all sooooo... much!
Posted on Jan 03, 2009
  • HP Master
  • 705 Answers
I would suggest you try replacing the dev unit itself. This should rectify the loss of density on the one side. If you need a service manual for assistance with changing the dev unit, try http://www.TheServiceManualShop.com they will likely have one. I presume you have also checked the laser lens to see there is no toner spilled onto it? This usually only accounts for thin areas of blank print.
Posted on Sep 29, 2007
  • 3 more comments
  • Inky Fingers
    Inky Fingers Oct 02, 2007
    I think this web page may help you.http://www.everprint.com/online/partsdet...
  • Inky Fingers
    I may have misled you by referring to the part as a dev unit. I work mostly with Epson machines and often use their terminology in the wrong situation.
    I believe after having read further on the CLJ 3500 that the dev units are part of the colour cartridges as this machine uses the inline printing method rather than a carousel method.
    You say you have done a print-stop test (Did you run a calibration from the menu? If not - run one now) and found that the image is correct on the drum, but when transfered to the paper is faulty. This would suggest that the Secondary Transfer process is bad.
    The first area to check for a resolution to this is the bias contact to the High Voltage PCB. Check all the contacts in the area of the colour carts, ITB and transfer rollers. make sure they are not bent or dirty and are in good order.
  • Inky Fingers
    This is the HVPS Circuit
  • Inky Fingers
    If you need the service manual that these images came from (rather better and larger in the manual than when posted here) let me have your email address.
  • Inky Fingers
    Inky Fingers Nov 06, 2007
    Hey thanks for letting us know how you resolved the issue. We may now be able to better help anyone who has a similar issue.
SOURCE:
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
My Hp color Laserjet won't print unless all
You have to replace all empty cartridges...no other solution
Oct 19, 2009 | HP Color LaserJet 3500 Printer
HP 2600n will not except print jobs.
just reset the printer to factory settings , use the menu to find factory settings .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Color LaserJet Printer Problem
Have you tried changing the magenta and black toner cartriages?
Jan 26, 2009 | HP Color LaserJet 3500 Printer
Banner page printing
Go to the webserver in the hp 3800 via the ip-address. There you can switch this feature on.
Jul 08, 2008 | HP Color LaserJet 3500 Printer
Hp inkjet 3500 prints red as yellow
how do i get the printer to read that i have put in a new transfer kit.
May 06, 2008 | HP Color LaserJet 3500 Printer
Left side of page prints blank
Hi there in the paper handling menu check the paper size settings as it maybe as simple as the incorrect paper size has been set in the machine
Hope this works for you
Thanks J
Dec 12, 2007 | HP LaserJet 2820 Printer
Colors faded on left side of paper black and blue
Is it possible for you to clean the printheads manually with cotton buds and cleaning solution on this unit. Clean all thoroughly and this might just correct issue.
Sep 01, 2007 | HP Color LaserJet 3500 Printer
HP Color LaserJet 3500 Printer Logo
560 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
