Question about Euro-Pro S3325 Handheld Steam Vacuum
I have a hand and stick vacuum and use it for minor chores. The other day when I use it, the filter felt in the garbage can without noticing it. When I went to use it today, I found I no filter. Need your help.
  • Euro-Pro Master
  • 18,424 Answers
Electrolux 2 in 1 Ergorapido stick Vacuum. Motor runs then cuts out after 3 - 4 seconds. Sometimes it will run properly for 10 minutes so batteries are good. Why does it cut our usually?
If the hand held is working correctly (By itself) try pulling up a little bit on the 4 metal connection tabs on the wand. The connection tabs were not making a proper connection on my unit.
Oct 20, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
How can I replace the rechargeable battery?
Hi There,
Officially Electrolux don't want to sell the batteries so they discount the price of the hand held unit. Here in Australia they are called ergo rapido but it will be the smae everywhere I would assume. They will sell the battery on its own but it is more expensive than replacing the hand held part (without the filters) .
Jun 12, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I have a electrolux Pronto 2 in 1 and the suction really never seems strong plus the brush in the base doesn't turn and the vacuum has been plugged in for two days. how can I get more suction and make the...
There is a filter inside the main filter. Once that filter gets clogged it will loose suction. Pull the filter and clean it, you can wash it by hand. Turn the unit roller side up and check for a small screw cover that you can use a dime to loosen. This cover is used to remove the roller unit. Once out check and clean then check the gear assy. for miss-alignment.
Jan 24, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
My rechargeable "Pronto" vacuum has lost most of
First I would ask you to check the filter. There are two filters, one inside the other. Pull the filter out of the hand unit, stick your fingers down inside the filter and hold the outer filter and pull them apart. Be sure to clean the inner filter as well to re-claim some lost suction power. Please check the hose from the floor unit to the hand unit make sure it is clear and fits well. There has been some problems with this models battery's and you may be able to claim some repair due to a recall. I can not find a dealer in your area. But you can check the Electrolux support site.
Jan 15, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I was replacing the belt on my Eureka Smartvac 4870 and one of the felt gaskets (or part of it) popped out. I thought I put it in correctly, but the first I used it after replacing the belt, the gasket got...
I'm no expert but if you mean the felt on the roller, you have to replace the roller (expensive,esp. for such a minor part). So. I found some felt with adhesive in the craft section at Wal-Mart, trimmed it to fit and done deal. Felt reduces friction.
Dec 08, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Dyson Clogged?
take the hose off and stick it over a broom handle to clear any clogs. Check air filters,
Aug 27, 2009 | Electrolux Guardian Bagged Canister Vacuum
How to remove filter on beam model 2775
Remove the bucket and look up inside the tank. There will be a finger loop to help pull the filter from it's track. You can shake it clean by wrapping a garbage bag around the tank, squeezing the air from the bag ( so it doesn't puff dust back at you)and then wrapping the bag over your hand and reaching up towards the filter.
This filter has a flat metal spring in it and will snap back into place. It is not normally removed unless it has gotten damp or stinky from pet odour. It is weighted in the middle with heavy beads in a sewn pouch.
Aug 16, 2009 | Beam Industries 2775 Serenity Plus Central...
How do I change the flilter on the sebo upright
Depends on the filter you're talking about:
The first filter is in the bag area- unhook and lift off the bin door, then bend down and flick your finger onto the left hand spring that locks the long cylindrical felt filter in place and lift upwards - this will loosen and unlock the filter from the base - put your hand at the back or front of the filter at the front near the base and pull towards you - the filter should then slide off easily.
Or it could be the motor filter you are referring to; push the pedal all the way down on the pedal release to put the X1/X1.1/X4/X5 into the lay-flat cleaning position, and push back the grille on top of the hood - you'll see a push finger mechanism there of which the grille will then be unlocked and can be picked up.
Nov 11, 2008 | Sebo X4 Bagged Upright Vacuum
Central vacuum won't turn on
Check your filter to make sure that it is seated completely in the unit. There is a switch at the top that the filter has to press before the unit will run. It is there to protect the unit from running without a filter. If you remove the filter, and look up into the unit, you will see it. It's a longish white plastic piece that you can depress by hand. Listen for the faint click while you are inserting the filter to be sure the filter is depressing the switch. Good luck!
Jul 21, 2008 | Eureka Whirlwind Litespeed 5740 Bagless...
Something stuck in my FilterQueen Vacuum
You should be using a broom or mop handle to clear the wand - metal tubing. If you still need help please contact the manufacture at 1-800-344-1840. I did and they were very helpfull, they also sent me a manual at no cost.
May 25, 2007 | Filter Queen Cheetah II Ash - MU305...
Euro-Pro S3325 Handheld Steam Vacuum Logo
23 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
