Question about HP DeskJet 648c InkJet Printer
Printer It will not print anything and the yellow loght keep blinking
  • starborn59 Mar 10, 2009
    i just changed cartridges on my deskjet 3820, orange light still blinking, wont stop and wont print. help
  • 24 Answers
Do you get an error message on the computer screen?if yes - what is that message....? I am stating the various problem causes for the issue you have stated without even knowing if you do get an error message or not.it would get resolved if you try these steps correctly as mentioned.It should be due to one of these causes. Cause ---The top cover of the printer is open. Solution 1. Close the top cover of the printer. 2. Press the RESUME button. Cause --Printer senses that there is paper being fed. Solution 1. Press the RESUME button to feed the paper. Continue with the following steps, if the paper does not feed. 2. Turn the printer off. 3. Open the top cover of the printer. 4. Make sure that paper is not jammed in the printer. 5. Lift the right black rectangular paper sensor (located in the middle of the printer just below the silver rod on which the cartridge carriage slides). 6. Make sure that nothing is stuck under the paper sensor (you can blow under the sensor to remove dust). 7. Close the top cover of the printer. 8. Turn the printer on. 9. Try printing again. cause --The printer was waiting for you to insert paper and then did not print. Solution Press the RESUME button to eject the printed page into the OUT tray. cause --Printer does not sense paper in paper tray. Solution 1. Check to see if there is paper in the paper tray. 2. If there is paper, remove the paper. 3. Make sure that the paper width and paper length adjusters are set for the correct paper size. 4. Load paper in the paper tray. 5. Press the RESUME button. cause --The RESUME light blinks when the computer is restarted or turned on. Solution ---This problem may occur when the printer is on before the computer is turned on or restarted. The printer should be turned on after the computer is turned on and turned off before the computer is turned off or shut down. Press the RESUME button to clear the printer and get it to the normal state. cause--Printer detects a faulty, missing, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. The RESUME light will flash until it is closed. 2. Pull the top of the cartridge towards you until the cartridge unsnaps from the cradle. NOTE : Make sure not to touch the copper-colored contact tape on the back of the print cartridge. 3. Click here (bpa00585) (in English) to check that you have the correct cartridges. 4. If you have the correct cartridges, then pick up the black cartridge. Notice that it has an arrow on the top. 5. Hold the cartridge so the arrow on the top is pointing towards the printer. 6. Tilt the cartridge slightly towards you. 7. Keep the cartridge tilted slightly towards you as you insert the cartridge into the right cradle. 8. Push the cartridge firmly forward into an upright position. You will hear a click when the cartridge is firmly in place. 9. Pick up the color (called tri-color) cartridge. Notice that it has an arrow on the top. 10. Hold the cartridge so the arrow on the top is pointing towards the printer. 11. Tilt the cartridge slightly towards you. 12. Keep the cartridge tilted slightly towards you then insert the cartridge into the left cradle. 13. Push the cartridge firmly forward into an upright position. 14. Close the lid of the printer. You will hear the sound of the cartridge cradle as it moves to the right side of the printer. cause --The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. (Distilled water is recommended. Tap water might contain contaminates that could damage the cartridge.) NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Turn off the printer. 5. Unplug the power cord from the printer. 6. Clean the carriage contacts on the back wall of the ink cartridge carriage with a damp, lint-free cloth. 7. Use a dry, lint-free cloth to remove the moisture from the contacts. If the carriage contacts show noticeable damage, have your printer serviced. 8. Plug in the power cord. 9. Try printing again.
Posted on Sep 25, 2007
SOURCE:
Yellow light is blinking?
If the bottom amber colored light is blinking, the imaging drum needs replaced.
If the yellow print cartridge light is blinking, then replace the print cartridge (yellow toner).
Mar 24, 2014 | HP c9705a - Color Laser Jet 2500l Printer
Yellow ink blinking
Please clean the printhead using the software installed in your PC . Try printing now.
Apr 30, 2010 | Epson Stylus Photo R2400 InkJet Printer
Hp Besiness inkjet 1100 fault codes cayan maginta ink and paper lights come on dead
HP Business Inkjet 1100 stops everytime after the first line stars to print. The power is one, the ink drop light is lit, the "yellow" indicator light also on, and the paper light all on. None of them blinking. We replaced the yellow cartridge with a brand new HP 11 yellow cartridge. Turned the printer off and on to reset. Printer comes on everything looks good till you try to print anything, even a on line word doc? Then it happens again, so we replaced the yellow again...same thing. We ever cleaned print heads, Any assistance would be welcomed?
Jan 12, 2010 | HP Business Inkjet 1100dtn Printer
My printer keeps printing greenish and blue/yellow
I fixed this problem for free with advice from the canon experts at the canon website, without them trying to sell me anything like a "plan" as your website has proposed.
Dec 03, 2009 | Cannon Canon i960 Photo Printer
Yellow light keeps on blinking
one of the cartridges is dead and must be changed. buy new one and the problem will be solved.
Aug 02, 2009 | HP DeskJet 640c InkJet Printer
Test page prints out great but I cannot print out anything else..yellow blinking lights on yellow and cyan?
Hello, Please take the cartdriges out, shake them a bit, and put them back in. If this doesn't help, replace the cartdriges (and if this doesn't work either replace the printer to buy a better one :) )
Jun 11, 2009 | HP LaserJet 2550n Printer
My HP 1100 won't print after power outage during printing
Not worth it to fix. You can find 1100's on ebay for $30.
Mar 02, 2009 | HP LaserJet 1100 Printer
Won't print
This relates to the problem with Driver. Uninstall all the printer driver for this Printer and then restart. After that reinstall all the drivers. your problem must be solved.
Feb 04, 2008 | HP DeskJet 610cl InkJet Printer
Will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Oct 27, 2007 | HP DeskJet 960c InkJet Printer
HP DeskJet 648c InkJet Printer Logo
286 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
