Question about Philips HTS3371D Theater System
Low volume on Philips hts3371d - Philips HTS3371D Theater System
My philips hts3371d burnt because of wrong voltage
This is quite serious as unless the fault is checked the depth of the damage cannot be assesed. It can vary from a shorted capacitor , rectifier or driver regulator to a serious issues where the mother board and processor is affected. So take a consensus and estimate before we can proceed.
Oct 05, 2011 | Philips HTS3371D Theater System
Philips Home Theater System (HTS3371D) will not turn on. Approximately 2 years old, never had a problem. I woke up today and the red indicator light is off and the system is completely unresponsive. It...
Have you contact Philips customer service and described your problem? I would suggest you start with them. If your outlet is supplying voltage and the unit is not turning on chances are there is a fuse inside the unit that is blown. The unit would not be hot because a small amount current is no longer flowing into the unit which is indicated by the led light no longer being lit.
Aug 10, 2011 | Philips HTS3371D Theater System
I have hooked up the philips HTS3371D Surround system up according to the diagrahm shown. I then went to the audio tab and selected audio on for surround on but it it does not come on. I have coax instead...
hi re check your wiring it doesn't matter what input you want to use the important is proper settings and connection of the source going to the surround system. then make sure the connectors or the coax cable is good. good luck
Jun 12, 2011 | Philips Televison & Video
Latest software update
The latest firmware update for this model would be located here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=HTS3371D/F7&scy=ca&slg=en
Jan 21, 2011 | Philips HTS3371D Theater System
Philips HTS3371D Theater System Logo
19 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
