Question about Groove Tubes Power Back 5,250-Watt Portable Generator #GT5250-WK
I've noticed oil leaking from the unit but don't know where its coming from.
    Master:
  • 452 Answers
Check at joint between engine and gen, its usually the engine oil seal need replacing u will need to split engine from gen, and replace the oil seal
Posted on Oct 15, 2013
Engine light comes on
sounds like you need to look at were it is leaking so the light don,t Come On Cause you might need to replace Oil Sending Unit Plug But first Look For the Leak did you change the Oil After Bying it OR Did It Just Happen ?the Light Comes On to Worn You Something IS Wrong So it,s Saying look At ME I,m Leakin So Fix Me Ther Ya go let Me Know What it was Thank,s For your time
Mar 04, 2015 | Cars & Trucks
Coolant leaking from R1 bottom of engine
FYI This has just happened to me.
Bike has been stood for a few weeks and i started it. Noticed the temp was unusually high (105-110) so switched off, checked coolant and it was dry.
I topped up and noticed the coolant leaking from what appears to be a hole in the engine sump casing.
Im a fairly fast worker and i managed to remove the entire exhaust system down to the header pipes and drop the oil and remove the sump casing in around an hour.
It might take longer if you don't do much mechanical stuff. (I'm just a hobbyist btw not a mechanic).
It turns out that the hole in the sump casing is actually linked to a coolant overflow pipe internally. So don't worry coolant is NOT mixing with your oil (and therefore oil is NOT mixing with your coolant!)
So obviously there is something more to this than meets the eye.It turns out that on all Pre2006 R1's the Water Pump is internal and if it leaks, You guessed it, It used this overflow pipe to stop the coolant mixing with your oil.
This is where my mechanical knowledge ends and i will be taking my bike to a real mechanic to swap out the water pump for me.
The good thing is, if you already remove your exhaust system and drop all your oil etc this will save around 1-2hours of labour at the garage!When they've fixed, get them to replace the oil and filter and leave them your exhaust if you like to fit and they can run it up and test it before returning to you working:)
Samantha x
May 17, 2012 | Yamaha YZF-R1 Motorcycles
I own a 2004 Subaru Impreza RS with 104,527 miles on it. Recently, I've noticed the car shakes a bit when it idles. Today, I turned it on and it sounded awful- very shaky, loud, and stuttering. I...
if you have ever looked under these cars they have places for oil to go but not on the ground. keep and eye on the oil. did it run a little smoother with oil
Sep 19, 2011 | 2004 Subaru Impreza
2003 Ford Escape transmission leak. 175 K miles. Tranny rebuilt at 120 K miles. It appears to be leaking where the tranny bolts to the engine. I've checked the axels and transmission pan and all...
This is quite tricky, the oil leak can be only due to a failure of the OIl seal or that the bearings after being worn out can damage the oil sealing.
So it is best that the unit be taken out in the engine side to be probed.
Now since the leak is more when the engine runs it is better to take down the unit for an overhaul , confirm and then replace the seal / bearings.
Jun 13, 2011 | 2003 Ford Escape
Hi there i have a 1989 883 sportster, i have removed the engin from the frame, and i have noticed that a small amount of oil is slowly leaking out of the lower front mounting hole(where the bolt normaly...
Well, I don't know if it's normal but I've seen this on several occasions. Technically, the cases should be sealed with a sealant and not depend on the engine case bolts to prevent oil leakage. But, over the years of operation, the sealant has been compromised by heat and vibration so it isn't unusual that the a bit of oil leaks out of the engine cases when the bolts are removed. It will probably reseal when you put the engine back in the frame and re-torque the bolts but there's no guarantee.
Good Luck
Steve
Jun 10, 2011 | 1979 Harley Davidson XLH 1000 Sportster
Smal puddle under car. the transmission pan is wet (not soaked) and I cannot find a leakage point
First thing you need to do is clean everything off so there is no residue anywhere. Then run the vehicle and watch for seepage....everywhere.... First, make sure what you are seeing is actually trans oil (reddish and much thinner than engine oil). Make sure you check the bellhousing also. If the leak is coming from the front seal it will blow back on the pan when you are driving. Check cooling lines and their connections at the trans.
If you have checked everything over carefully and still can't locate the leak, you could try using a quality sealer such as lucas. Only time it won't work is if a line or fitting is leaking or if the leak is just too large. That product is one of the few I've seen that won't damage the friction material inside the unit. Don't permit the trans to run low and don't expect overnight results from a sealer. It takes a little time to restore a dried out or brittle seal.
May 12, 2011 | 2002 Jeep Grand Cherokee
Oil pressure gauge goes up to 80 pounds
80 lbs is good. It's more like around 50, it's probably the oil sending unit. Take a look at it aand make sure it in't leaking. If there is any oil covering it and none coming from above it is leaking. I don't know engine size, but they are usually located around the oil filter.
Apr 29, 2011 | 2000 Jeep Grand Cherokee
I have oil coming from the oil filter houseing unit?
It is possible that it could be leaking oil from the oil filter adapter (Sometimes called housing) where it mounts to the engine block. Leaks here are pretty rare. More likely, your oil pressure sending unit is leaking oil. It screws into the back side of the oil filter adapter and can sometimes make it look like the adapter is leaking.
Dec 27, 2010 | 2006 Chevrolet Impala
I have been using a KB3030B electric pressure washer to clean patio and have notice oil leaking from bottom of casing. Don,t know where its coming from nor what to do
The pump has a section with pistons that must have oil. The oil/piston housing is between the motor and the water portion of the pump. Some seals, somewhere are leaking. If you run it without oil it will destroy itself. You must get it fixed and I would do so before using it again.
Jun 10, 2009 | Karcher K2.26 Electric Power Washer
Groove Tubes Power Back 5,250-Watt Portable Generator #GT5250-WK Logo
77 people viewed this question
Top Groove Tubes Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Groove Tubes Electrical Supply Expert? Answer questions, earn points and help others
