Question about Frigidaire Kitchen Ranges
I own a 1998 Frigidaire Gallery Professional Series electric range, Model # FES388WGCC. I am trying to replace the clock, temperature, oven control device which is installed behind the front panel of the oven. I have the replacement part # 318012903. I haven't found a way to remove the front panel to gain access to the old part and replace it with a new part. I would greatly appreciate hearing from anyone who has been able to do this. Many Thanks
4 Suggested Answers
  • 7 Answers
SOURCE: Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Posted on Feb 09, 2008
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
Posted on Sep 05, 2010
SOURCE: Frigidaire Professional Series Range - F30 ERR
door will not unlock after cleaning
Posted on Jan 22, 2011
Getting f10 on oven
Hi Dave, thank you for allowing me to assist you!
Typically error code F10 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps! - Z
Aug 22, 2014 | Frigidaire 30 in. Electric Gallery Series...
F10 code after frigidaire wall oven on for 15 minutes
Good Morning Dave, thank you for allowing me to assist you!
If you are getting error code F10, it typically means that your range is experiencing an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your range by either unplugging it or flipping the household circuit breaker off for about ten minutes. If the error code persists, I would be advisable to reach out to a professional to proceed further. Most likely the RTD (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Nov 21, 2013 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire gallery professional series oven I have
Good Afternoon John, I am happy to assist you!
I understand you are seeking a manual and I'm assuming your model number is GLEFM397DS, posted above. If so, I have located the Owner's Guide on the manufacturer website. Here you will be able to access step by step instructions on how to operate the oven. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Sep 16, 2013 | Frigidaire Gallery GLEFM397DS Electric...
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
Electrical panel went blank. Hence can't operate the oven. Stove works fine.
Hi. Interesting. My Figidaire Gallery Professional gas stainless went blank 2 days ago. Model FGF379WECS. So I'm googling...
Your Service Manual is located at (document #2 in link):
http://www.retrevo.com/support/Frigidaire-GLEFM397D-Ranges-manual/id/2367bh351/t/2/
Part Number
316418704
Description :
Clock/Timer, electronic, w/mini oven, ES510
Rick
May 15, 2010 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery Professional Series Oven Won't Turn On
Suspect a bad oven element. Worse case is a bad oven relay on the clock control board.
Sep 20, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Hello! I have a Frigidaire (made by Electrolux) Gallery Professional Series gas range/electric oven, model #FGF379WJCA (manufactured in 1998). The appliance came with the house we moved into 2 years ago. ...
for question 1 the wire for the ignitor is bad has to be changed not an easy job if you can live with it itll be ok if not its best to call in a tech or take to repair shop not sure about question 2 sorry
Aug 30, 2009 | Electrolux Frigidaire Professional Series...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
1998 frigidaire wall oven intermittant f1 code
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Aug 02, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Electric Smoothtop Range......getting F 1 error on digital display
Jul 15, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Kitchen Ranges Logo
79 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
