Question about Brother P-Touch 1180 Label Printer
My PT-1280 will not turn on. I put in new batteries but it still does not work.
I have 2002 pt . I have no problem with it, started it and put in gear, went to pull out and it shut off, now it won,t start back up, put new battery in, new switch, still nothing,
Possible starter failure if the engine doesn't crank. You can try tapping on the starter motor using a blunt object while turning the key to see if it starts. If it starts, suspect a defective starter motor. If it is a manual transmission, you can push start it in gear
Nov 21, 2015 | 2002 Chrysler PT Cruiser
PT 1280 suddently printing miniscule letters. Can't reset, have turned off using Shift/clear buttons, but doesn't change after settings redone.
What size tape are you using? If you have switched from half-inch to quarter-inch tape, then chances are that the printer is working correctly as the general size of the print is determined by the size of the tape. Beyond that, you can use the Text button at the top-center of the keyboard to enter the options for customizing the print such as the font used, the size (small, medium, or large), the width of the letters, and the style (such as bold, outlined, or shaded).
Jun 05, 2015 | Brother P-touch PT-1280 Label Printer
Won't turn on after changing to new batteries
Did you put the batteries in correctly? It could be that simple.
Mar 20, 2014 | Brother P-touch PT-90 Personal Label Maker
Nokia 1280 is always hot
nokia 1280 is veray hot
Jan 15, 2013 | Nokia 1280 Cell Phone
I would like owner's manual for the brother model #PT-1280,printer
You can go to brother-usa.com and click on the "support" tab, then scroll down a little and you will see "manuals". Click on that and enter the model # and you should be able to download the manual.
Jun 09, 2011 | Brother P-touch PT-1280 Thermal Label...
Brother PT1280 P-touch Machine User's Manual Download
You can download and print the instruction manual in PDF format from Brother PT-1280 support website by clicking this link
On the page which opens, click on the 'Download' button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download the latest version of Adobe Reader. Thanks for using FixYa
A 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Brother P-touch PT-1280 Thermal Label...
Brother HL 1280
is the actual model is Brother PT 1280 .. it';s a labeling p-touch..if yes..then you can download the user manual here...
http://www.brother.com.my/my/productDetail.asp?model=PT-1280&Rnum=241294
May 24, 2010 | Brother HL 1260e Laser Printer
2002 PT cruiser trying to start with no keys!
I would check your wire harness. The starter is close to where you would be working on the radiator. I have not had the pleasure to put one in but i know its a tight squeez in there.
Jul 22, 2009 | 2002 Chrysler PT Cruiser
My PT 1280 won't cut. Can I get a new blade?
The parts list doesn't show a blade alone, part # LN6775001 is the cutter lever, could be what you need. About $3.00
Jun 23, 2009 | Brother P-Touch - PT-1280 - Home and...
Brother P-Touch 1180 Label Printer Logo
209 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
