Question about Dynabrade Air Tools & Compressors
Dynabrade air sander wont work. nothing is broken, i cleaned it and ran some oil and new grease but no go.
  • 226 Answers
SOURCE: AIR VOLUME REQUIRED
You need to look at the tool cfm requirements because they are posted on the package or usually in the ads. Your compressor will run the sander, just how long at a time will depend upon your tool's cfm. Rick
Posted on Apr 15, 2009
  • 226 Answers
SOURCE: tool wont work with air compressor, and shoots out
Normally when the air will not drive the tool, it is because 1- the tool is rusted up inside, 2- there is no lubrication of the moving parts - which can be remedied by putting something like WD40 in the inlet with the air switch open, 3- the drive parts are broken or worn out, 4- not enough air volume/pressure to run the sander.
You probably need to spray some lube as above & see if that will get it to work. Also turn the sander part by hand. Rick
  • 226 Answers
SOURCE: I have 5
You can get new pads at the automotive paint stores in your area. They are not expensive. Most of these wholesalers have a service department that can r&r yours. Hope this helps you, Rick
Posted on Apr 26, 2009
  • 98 Answers
SOURCE: Dynabrade sander doesn't spin
check the exhaust muffler. or just take it off and see what happens.
there is usually an inlet air adjustment on the palm sander itself one of these will correct your sander.
if not, and your air supply is good. put some air oil in it or even a light weight oil will work.
if none of this is the correct action to get it going. its probably toast!
Posted on Mar 03, 2010
SOURCE: my 10mm air belt sander front end bearing is
no doubt you will take the old bearing off, and take it in to a bearing seller and they will no doubt, they will be able to supply an exact replacement.
Copy paste that address, below to the address bar, and that will show you all the bearing sellers in Sydney.
http://maps.google.co.nz/maps?sourceid=chrome&um=1&ie=UTF-8&q=bearing+sales+sydney&fb=1&gl=nz&hq=bearing+sales&hnear=sydney&view=text&ei=cSynS-fuKoOqtgPV8I29BA&sa=X&oi=local_group&ct=more-results&resnum=1&ved=0CCQQtQMwAA
Posted on Mar 22, 2010
Why the oil will come out from the sander? how many oil drop must regulate the regulator
Oil coming out of the sander indicates that too much oil is flowing into the the supply air. The rule of thumb for oiling an air motor is 1 drop of light machine oil per minute, per 10 cfm of air.
Jan 16, 2014 | Dynabrade Air Tools & Compressors
Where to apply grease
There are no parts in your sander to grease. The only place there is grease is in the three sealed bearings on the armature and in the platen. Everything should be clean and dry inside the sander to make it less likely for sawdust to stick inside the tool. Blow everything out and replace the bearings if they are not turning freely and smoothly.
Dec 01, 2012 | Dewalt D26441 - Palm Sander, 1/4 Sheet
Can i use my dynabrade sander to car polishar
I would not recommend it for that purpose. A polisher has a much SLOWER RPM than a sander and you would probably cause paint damage from burning, secondly the polishing pad might not be rated for this higher RPM.
Feb 17, 2012 | Dynabrade Tools & Hardware - Others
A friend gave me a 210055 3/32 Sander. I would like to get a manual for it.
Hi vepa, my name is John. Welcome to FixYa. You can get it here. www.mastertoolrepair.com . Thanks for choosing FixYa...John
Dec 05, 2010 | Dynabrade 6" Dynorbital-Spirit Random...
Mar 03, 2010 | Dynabrade 56818 5" Supreme Vacuum Orbital...
I ned the internal vein parts.
One of the cool things about the Dynaorbital Spirit sanders is that, they were designed to be the lightest sanders out there (as opposed to the Dynaorbital supreme). This is nice as it keeps hand fatigue to a minimum. Another cool thing about the spirit, is that it was designed to be able to change out the entire drive motor all at once. The drive motor being the rotor with the vanes on it. These motors are available from dynabrade directly. replacing one vane only will tear the sander body up fast. I would recommend you get the replacement motor from them. They can be found here:http://www.dynabrade.com/dyn09/intro/selregmark/index.html
TIP: When replacing the motor, be very careful not to compress the sander body (i.e. bench vice).Dynabrade sells a rubber grip collar for this operation. then you just R and R (remove and replace) the motor and yer' good to go!!
May 12, 2009 | Dynabrade 59035 5 Non Vac Dynaorbital...
I have 5" Dynabrade Orbital sander that needs a new sanding pad and could probably use a going over at the same time. Who does this work? Cost
Apr 21, 2009 | Dynabrade Air Tools & Compressors
AIR VOLUME REQUIRED
Apr 14, 2009 | Air Tools & Compressors
As soon as i apply my sander to the surface it stops sanding
hi a major problem with pneumatic tools is that nobody ever seems to oil them! try droping tool oil or a light machine oil down the air inlet and leave over night and then run the tool on full ,if this doesnt work then strip the tool and clean and make sure that the blade sealing surfaces are good
hope this helps ian
Mar 21, 2009 | Dynabrade 57810 Dynabug Orbital Air Sander...
Tool wont work with air compressor, and shoots out air and the sander does nothing
Mar 08, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
Top Dynabrade Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Dynabrade Air Tool and Compressor Expert? Answer questions, earn points and help others
