Question about Dell 924 All-in-One InkJet Printer
What is he process to replace the cartridges?
  • Dell Master
  • 4,338 Answers
Lift the printer unit from under the scanner, there should be a support to hold it up while changing the cartridge. The cartridges will align them selves automatically once you open the top, so you can access them easily. The manual for you printer can be found here:
http://support.dell.com/support/edocs/systems/924/en/index.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 23, 2009
  • Dell Master
  • 3,866 Answers
Well make sure you have you model printer when you go to the store, take out the old one if you want to be exact and show it to the store and they will give you the replacment one these just snap out or you push a lever and so on its really easy change, good luck
Having trouble removing ink cartridge on hp e709n printer
Hello Sandi,
According to the product information you provided in your post, the following information should be able to provide you with the information needed to help you remove and replace the ink cartridges for your printer.
Ink Cartridge Removal Steps:
Keep your printer plugged in and on during this process.
1. Open the cartridge access door. The carriage moves to the center of the product. Wait until the carriage stops moving before proceeding.
Illustration of cartridge access door
2. Each ink cartridge will have plastic tabs located directly in front of them. Press in the tab on the front of one of the cartridges, and then pull it out and up to remove it from its slot. Once you have pressed the tab, you then pull up and out on the cartridge and it should come out easily.
Illustration of process:
3. Repeat this step to remove all cartridges from their slots. Remember that each ink cartridge will have to be removed individually if your printer has more than one cartridge.
Replacing the cartridge with the new one:
1. Remove the ink cartridge from the packaging and then remove the protective covering.
2. Hold the ink cartridge in the same position as you removed the old ones. Push in and then down on the new ink cartridge which should lock them into position with the tabs automatically and you will you will usually hear a clicking noise when this is done.
3. Close the cartridge access door. The printer will automatically reposition the cartridge print head assembly for you.
This should complete the process and you should now be able to print. Some printer will ask or recommend that you print a test page so that it can calibrate the desired ink usage, position, darkness, etc. If this appears on your screen just follow the directions as prompted to complete the test page.
I hope this provides you with a bit more clarity for removing and reinstalling your printer ink cartridges. If you have any further questions or need additional assistance, please feel free to ask. Have a good day.
Jun 20, 2012 | Unknown Office Equipment & Supplies
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
Loaded new print cartridges went through alignment check /scan error message none alignment.Reloaded cartridges went through same proceedure same result.unable to print anything
Are you checked working condition of scanner before replacing the cartridges?. If scanner is not working align process could not completed..cancel the align process then you can able to take prints..
Sep 10, 2011 | HP Photosmart 4180 All-in-One Printer
I just changed all the cartridges in my epson stylus sx12 but still says theyre empty
p { margin-bottom: 0.21cm; }
According to your problem first make sure that you have installed the cartridges properly. Go the the printer properties in control panel and follow the steps open the printinging preferences tab> maintainance tab > Ink cartridge replacement> then the window will show the process of the replacement of ink cartridge. Follow those steps of replacement. Then let the cartridge be processed, it will take a few time. And then your cartridge replacement will be finished. Then align the cartridges from the alignment option in printing preferences as well. If it doesn't solve your problem then the cartridges are faulty, replace a new set of cartridge is recomended.
Jun 09, 2011 | Epson Stylus C88 InkJet Photo Printer
How to remove the ink cartridges?
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing. r_2.gif Open the printer cover. r_3.gif Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position. 98a04.gif r_4.gif Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it. 98a05.gif r_5.gif Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape seal from the cartridge. Do not touch the green IC chip on the side of the cartridge. 98a06.gif r_6.gif Place the ink cartridge into the ink cartridge holder, and then close the ink cartridge clamps. Do not apply excessive force to the cartridge. 98a07.gif r_7.gif Close the printer cover. r_8.gif Press the fontb1.gif maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When the ink charging process is finished, the printer returns the print head to its home position, the fontp.gif power light stops flashing and remains on, and the fontb1.gif error light goes out. 98a08.gif If you feel that my answer helped you then please give a vote for my answer.
Apr 04, 2011 | Epson Stylus C43UX InkJet Printer
R 340 cartridges have remaining ink but printer
just go to the process of ink cartridge replacement without actually putting in new ink cartridges, sometimes printers make read errors, just make sure ink cartridges are placed properly to position.
Jan 17, 2010 | Epson Stylus Photo R340 InkJet Printer
Even with brand new ink, my canon iP4500 won't work
A few basic causes.
1. The cartridges you bought iwere not proper HP ones and many "clone" cartridges are known to have problems with the ink level chips
Take them back and get them replaced with a different brand
2. They are original cartridges but may still be faulty (rare but possible)
3. Your print head is clogged or faulty
Run your printerthrough the head cleaning process a few times and see if it clears up.
4 your cartridges are out of alignment
run the cartridge alignment process
if this information was useful please click below
Aug 12, 2009 | Canon Pixma iP4500 InkJet Printer
Ink cartridge won't release
The replacement process isn't always very intuitive. Fortunately, HP.com publishes a web page with detailed instructions:
Replace the Print Cartridge
Good luck.
Oct 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Error f2 in copier ar 5127
F2:
00:TONER SENSOR
02:TONER SUPPLY PROBLEM
04:WRONG COUNTRY,WRONG CARTRIDGE,DRUM
05:DRUM PROBLEM,WRONG CARTRIDGE
39:PROCESS UNIT THERMISTOR PROBLEMS
58:PROCESS HUMIDITY SENSOR PROBLEM
Sep 25, 2008 | Office Equipment & Supplies
New Magenta Ink is not recognized after installed
Hi, it sounds that the issue can be caused by a defective ink cartridge that installed or a printhead that can recognize magenta ink cartridge. To identify which causes this issue please try the following:
1. Reseat ink cartridge
2. Replace ink cartridge with a specified ink cartridge for your printer.
3. If above steps wont resolved that issue, please call your printer manufacture and ask for service referral or process warranty options.
Tirzo
Oct 21, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
59 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
