Question about Vacuums
Shop vac model 7025 blows dust out of lid - Vacuums
SOURCE: shop vac
Vacuum is less than a year old and died in the middle of a use. No power... tried to plug it into 3 known, good outlets. Suggestions?
Posted on Jul 06, 2008
  • 13 Answers
SOURCE: Shop vac
is the filter in place and in good condition. To find the filter just unhook the top and lift it off.
Posted on Nov 01, 2008
  • 297 Answers
SOURCE: my shop vac blows dust as soon as it's turned on
there should be a cover or sock over the filter,this will stop the dust.the paper filter is the part that can not get wet. if you don't have a cover for your filter use an old sock or something simular to a sock.
Posted on Aug 04, 2009
sleprocks
  • 147 Answers
SOURCE: on the back of the shop vac there's a hole...what
should have a exhaust filter in the hole. it is round and 5-6 inches long with a type of filter on the end.
Posted on Oct 22, 2009
  • 48 Answers
SOURCE: How to stop dust from escaping the shop vac tub
The only sure fire way is to use a filter, bag and ensure you have what they call a "noise muffler" but in all reality it's a filter that not only dulls the noise but doesn't let dust escape via the access there in the rear.
Posted on Apr 15, 2010
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
Tip
Safe way to vacuum drywall dust
SAVE THAT VAC
One of the hardest things on a shop vac is drywall dust. It is so fine that it gets through the regular filter and destroys bearings/bushings and ruins the motor. Just the other day, a friend commented that he had to get a longer hose as his vac was blowing out a lot of drywall dust because the filter was slipping down!
High performance filters are available at most hardwares and box stores. They resemble the paperbag filters in carpet vacuums and catch the drywall dust so that the bag can just be thrown away when done. The bag is U-shaped to install in the shop vac and have clearance around the regular cartridge filter. The inlet has a rubber seal that pushes around the inlet on the inside of the tank. Just run the vac normally but spare it and your lungs!!!
on Mar 02, 2010 | Vacuums
Kobalt 10 saw blows dust everywhere ,even with a 2 shop vac connected to the dust chute .
It is possible that the dust chute on the Kobalt saw is plugged, not allowing the vacuum to pick up the dust. Run a rod through the dust tube and see if that clears it.
Jun 19, 2015 | Shop Vac Vacuums
Motor makes loud racket and smells like burning, but still works.
Bag? There is a paper filter and maybe a foam filter ... bag? Maybe this is a newer model that I am not familiar with. Anyway ... ...
It sounds like your motor has been eating dust. Please check here for your repair: http://www.shopvac.com/support/
Feb 21, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
My children cleaned our Eureka 4d boss bagless vacuum and threw the lid to the dust cup in the trash. How do i find a replacement lid? The vacuum does not work without it,
Check with a vac repair shop to see if they might have a used top. If not they should be able to order you one. You could call the customer service number located on the label of the vac located on the back or the bottom of your vac for assistance.
Joe
Nov 21, 2009 | Vacuums
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
Mar 23, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Have a Sears shop vac, mod 113.172. The motor doesn't take in
If the motor turns, you should have suction. Put the hose on the exhaust side of the motor if there is a connection, and try to blow it out. If you can't, try using a garden hose or toilet snake to clear the hose. IF the hose is clear, and the problem continues, check the float in the cage below the motor. It should be down at the bottom of the cage. Also, if you haven't been using a bag or foam cover for the cage, it is possible for leaves to clog the motor.
Mar 15, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Shop vac
Nov 01, 2008 | Shop Vac (464-38-10) Canister Wet/Dry...
Vacuums Logo
88 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
