Question about Samsung LE37B650 37 in. HDTV-Ready LCD TV
Screen failure - Samsung LE37B650 37 in. HDTV-Ready LCD TV
  • 2 more comments
  • Jarl Sandberg
    Jarl Sandberg Oct 12, 2013
    The screen started flashing brigt/normal color, but now it is konstantly brigt... like negativ pictures.
  • Jarl Sandberg
    Jarl Sandberg Oct 13, 2013
    When it's tuned on it is ok for 5 minits then it begins to fail.
  • Jarl Sandberg
    Picture :-)
  • Jarl Sandberg
    Jarl Sandberg Oct 17, 2013
    No solution for this error?
My optiplex 320 is making two high pitched beeps on starting boot, also im not getting anything on the monitor
James,
It sounds like the refresh rate is set to high. Since you do not mention what OS is installed I have listed information on how to change in Windows,XP.
Start the computer and press the F8 key. Choose Safe Mode. Once the system gets into Windows follow the steps below and then restart the computer. If this does not resolve your issue email me at my email address below and include your OS information.
How to Change the Screen Refresh Rate of Your Monitor
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Or your system is giving off a beep code in which case the beeps come in a 3 beep sequence. Below is the beep codes and what each represents.Beep Codes
Troubleshooting steps and more information about the OptiPlex 320 beep codes Beep Codes Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3-1 through 2-4-4 DIMMs not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller Test failure 3-3-1 NVRAM power loss 3-3-2 NVRAM configuration 3-3-4 Video Memory Test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No time tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math coprocessor test failure 4-4-4 Cache test failure
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Sep 18, 2013 | Dell Computers & Internet
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Why is my lap top just intermittently beeping with a black screen
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 07, 2012 | Dell Inspiron M5030 Laptop
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Jul 27, 2011 | Dell Dimension 9200 PC Desktop
My Dell Inspirion Mini 10 is beeping 8 times when I turn it on. Nothing on the screen.
Try holding Fn + End with battery and power cord out and while still pressing Fn + End plug only power cable back in and try to power on.
Oct 12, 2010 | Computers & Internet
Beeps on my computer
If its a Repeating short beeps, this tyically implies power supply or mainboard issues. However here is list of Pachard Bell Beeps codes for the main boards.
1 1 3 CMOS read/write failure
1 1 4 ROM BIOS checksum error
1 2 1 Programmable interval timer failure
1 2 2 DMA initialisation failure
1 2 3 DMA page register read/write failure
1 3 1 RAM refresh verification failure
1 3 3 First 64k RAM chip or data line failure
1 3 4 First 64k RAM odd/even logic failure
1 4 1 Address line failure first 64k RAM
1 4 2 Parity failure first 64k RAM
2 1 1 Bit 0 first 64k RAM failure
2 1 2 Bit 1 first 64k RAM failure
2 1 3 Bit 2 first 64k RAM failure
2 1 4 Bit 3 first 64k RAM failure
2 2 1 Bit 4 first 64k RAM failure
2 2 2 Bit 5 first 64k RAM failure
2 2 3 Bit 6 first 64k RAM failure
2 2 4 Bit 7 first 64k RAM failure
2 3 1 Bit 8 first 64k RAM failure
2 3 2 Bit 9 first 64k RAM failure
2 3 3 Bit 10 first 64k RAM failure
2 3 4 Bit 11 first 64k RAM failure
2 4 1 Bit 12 first 64k RAM failure
2 4 2 Bit 13 first 64k RAM failure
2 4 3 Bit 14 first 64k RAM failure
2 4 4 Bit 15 first 64k RAM failure
3 1 1 Slave DMA register failure
3 1 2 Master DMA register failure
3 1 3 Master interrupt mask register failure
3 1 4 Slave interrupt mask register failure
3 2 4 Keyboard controller Test failure
3 3 4 Screen initialisation failure
3 4 1 Screen retrace test failure
3 4 2 Search for video ROM in progress
4 2 1 Timer tick interrupt in progress or failure
4 2 2 Shutdown test in progress or failure
4 2 3 Gate A20 failure
4 2 4 Unexpected interrupt in protected mode
4 3 1 RAM test in progress or failure>ffffh
4 3 3 Interval timer channel 2 test or failure
4 3 4 Time of Day clock test failure
4 4 1 Serial port test or failure
4 4 2 Parallel port test or failure
4 4 3 Math coprocessor test or failure
low 1 1 2 System Board select failure
low 1 1 2 Extended CMOS RAM failure
hope this helped
-Keiffertech
Jun 18, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
ON POWER UP SPLASH SCREEN DISPLAYS THEN FREEZES
I see failure in booting. I'm afraid your HDD has problem, have check with JVC Service Center near you, chances are high of HDD failure like you have that can be repair.
Feb 28, 2010 | JVC Everio GZ-MG130 Camcorder
I have 2 GX520's that are buzzing when trying to boot
If your computer beeps during start-up:
  1. Write down the beep code
Code
Cause
1-1-2
1-1-3
NVRAM read/write failure
1-1-4
1-2-1
1-2-2
1-2-3
1-3
Video Memory test failure
1-3-1 through 2-4-4
Memory not being properly identified or used
3-1-1
3-1-2
3-1-3
3-1-4
3-2-2
3-2-4
Keyboard Controller test failure
3-3-1
NVRAM power loss
3-3-2
Invalid NVRAM configuration
3-3-4
3-4-1
3-4-2
3-4-3
4-2-1
No timer tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
4-3-1
4-3-3
4-3-4
4-4-1
4-4-2
4-4-3
Math-coprocessor test failure
4-4-4
Cache test failure
Apr 11, 2009 | Dell OptiPlex GX520 PC Desktop
E125 screen failure symptoms
As a rule the failure of the LCD on a Casio pertains to greying out of the top 1/3 portion of the screen. The touch screen - the part that senses your stylus inputs i.e. taps, double taps, tap & hold / drag continue to work. Seems like the failure is not in the LCD but the fluorescent lamp at the top end of it. It could be the lamp itself or the inverter circuit. Have an experienced technician check the lamp out. It is not a very diffucult item to replace. Nor is there any desoldering / soldering involved.
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
Samsung LE37B650 37 in. HDTV-Ready LCD TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
