Question about Cisco Coco Phone Retro Handset 3.5mm
No one can hear me using my Coco Retro handset
BUNN MY CAFE BAD TAST WITH COFFE OR HOT COCO
Try really cleaning the basket that the water and coffee or cocao goes into. If you don't really clean it well, it will have the taste of the last thing brewed mixed in with the new brew. Coffee followed by coffee should not be a problem, but coffee followed by cocao will give the cocao a coffee taste, and visa versa.
Nov 21, 2013 | Bunn My Cafe MCU Universal 4-in-1 Single...
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
Handset problem
It sounds like you have a defective handset cord or handset. First, at your phone, switch your handset with another phones handset that you know for sure works. From your phone make a test call. If the caller can now hear you, the original handset from your phone is defective. If the caller still can not hear you, switch your handset cord with another handset cord from another phone that you know works. From your phone make another test call. If the caller can hear you, then your original handset cord is defective. You can purchase another handset cord from your local office supply store. Your phone uses a standard handset cord. It may be difficult to match the original color of your handset cord. Be sure to take your defective handset cord with you, so you can try to match the color. If the caller still does not hear you. Put your original handset and original handset cord back on your phone. Then plug your phone in to another wall jack, that you know works with another phone. The other phone needs to be an identical phone to yours (same number of buttons and same model number. The model number can be found under the phone). Wait approximately 90 seconds, sometimes longer, after you plug your phone into the other wall jack. Now, make another test call from your phone. If the caller can now hear you from your phone with it plugged into another working jack, then you have a defective station port or jack where your phone was originally plugged in at. If the caller still can not hear then you have a defective phone.
Nov 19, 2008 | NorStar M7208 Corded Phone
Panasonic kx-fpc141
Try Ths on the handset Be sure the TALK indicator is off.Press LOUD/RINGER button on the handset, the curreent ringerwill sound. To change the Volume press the LOUD/RINGERagain within 5 secs , and the new ringer will sound, you must press LOUD/RINGER within 5 secs or the volume will not change.
May 08, 2007 | Panasonic KX-FPC141 Plain Paper Thermal...
Cisco Coco Phone Retro Handset 3.5mm Logo
27 people viewed this question
Top Cisco Audio Players & Recorders Experts
Prashant M
Prashant M
ray gallant
Steve K
Are you a Cisco Audio Player and Recorder Expert? Answer questions, earn points and help others
