Question about GE Cooktops
GE coquette stove
The elements don't seem to come out so I can clean the stove top and catch trays under the elements... Do they come out? I don't want to pull too hard in case I wreck the wiring.
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Nov 28, 2014 | Maytag MGC5430 Gas Cooktop
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
I have a Fisher & Paykel CE901 36" electric
Sorry, I don't have a solution, but a similar problem. My CE901 is 6 years old. One of the regulators broke after one year. The repair (under warranty) caused an electric fire a couple of weeks later. After much complaining, I got a replacement cooktop from F&P. Now, 5 years later, one regulator stopped working, no longer turns on the element. (I guess that's better than no longer turning it off.) You are not alone. Seems like F&P is incapable of producing a simple regulator that works reliably.
Nov 28, 2010 | Fisher and Paykel 36 in. CE901 Electric...
How do I access the spill tray under the element of a chef stove in order to clean it?
Make sure that all of your burners are off and cool. Raise the stove top. It should tilt from front to back. There will likely be rods inside to hold the top open.
--Regards, --WoobieDog--
Jul 10, 2009 | Electrolux Cooktops
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
Ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
May 01, 2008 | GE Profile JP930 Electric Cooktop
Cooktops Logo
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
