Question about JVC AV-32D305 32" TV
There are faint lines at the top of the screen when the TV is on.
The TV is a JVC 32" bought in 2001. It started as lines at the top of the screen when the TV was initially turned on. Now these lines remain at the top of the screen. The TV still works fine. It seems thou that the lines are more abundant. What could be wrong?
  • inspector96 Apr 23, 2009
    Thank you for you help. I have not tested this as of yet but I suspected this could be a possible problem.
    President:
  • 2,992 Answers
There are capacitors in the set's vertical output circuit that need to be replaced. TV repairs should be handled by a professional because of the hazards involved, particularly with larger sets. This is a pretty minor repair, probably under $100.
Posted on Apr 23, 2009
  • Apr 23, 2009
    The caps will do the trick. I've seen that a lot in over 15 years on the road and in the shop. You'll find the caps around the vertical output IC heatsink. I'd suggest just changing all the electrolytic caps around there (only 6 or so) as they are cheap and you're in there anyway. A google search for your specific TV model and "vertical retrace" might turn up a list of part locations and values for you. Good luck!
Tv blinks a black screen off and on, and also getting a green line at top and bottom at times any suggestions? 10 years old
I have same problem, over 10 years old, only started when turned on, but does it @ anytime now . any solutions ? and this thing does weigh a ton. never had a problem ever, great tv, great picture, etc., anytime a function is initiated screen blinks on off at will, stays on for the most part, no other problem, but can this be repaired or is it time to buy a new tv ?
Oct 17, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Our JVC AV-32F703 has a black screen when we turn it on. The sound works fine. What could it be? The tv was purchased in Jan 03
try up the screen bottom in the fly back. if yoy see a white horizontal line the tv have a cold solder in vertical ic or is bad.
Apr 14, 2010 | JVC AV-32F703 32" TV
My JVC Plasma 42" screen TV is only 13 mths old but it does not turn on anymore. The blue button (power) comes on steady at first but then, after about 3 seconds, starts to blink and it won't go off -even...
CHECK UR POWERSETTING AND SLEEP TIMER SETTING......AND RE ADJUST IT
IF YOU STILL HAVE PROBLEMS GO IN TOUCH WITH JVC SERVICE AND ASK THEM FOR ADVISE....OR THE STORE U BOUGHT THE SET FROM
Nov 19, 2009 | JVC GM-V42UG 42 in. Plasma EDTV
Older JVC 32" TV has lines & fold over at the top of screen. TV is about 6 years old.
Check the vertical section .. You will find few Electrolytick capacitor..replace all with new one or replace the filter capacitor at vertical IC supply..
Jul 10, 2009 | JVC HD-52G787 52" Projection Television
White lines running across screen from right to left
when there is a line from right to left it means a verticle amplifier is faulty, remedy
change a verticle amplifier IC
dont forget to check some capacitors (electrolitic for change of values)
this will solve your problem.
Apr 07, 2009 | JVC AV-36D303 36" TV
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
Jul 31, 2008 | JVC AV-32120 32" TV
Jvc 32" has grouping of thin white lines at top of picture extending 4" down from top of frame
It sounds like you have a bad capacitor in the vertical circuit. The circuit needs to be checked out by a technician. Stargazer
Aug 12, 2007 | JVC AV-32D305 32" TV
JVC AC32F702
22uf/250v from the 180v flyback output and 100 uf/50v in vertical and the last 220uf/16-25v from 16v line of flyback.
Apr 28, 2007 | JVC AV-32F702 32" TV
JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Apr 12, 2007 | JVC AV-32F704 32" TV
JVC AV-32D305 32" TV Logo
167 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
