Oven top heating element not working
Hi Max447,
For safety Reasons you should cut off the power at the Circuit breaker. Test the oven to see if you can turn it on before working on it.
Nothing tough about removing the element. Open the door and remove the racks to give yourself room.
Where the element connects to the wall, remove the fasteners, and pull the element out.
To test the element. Use a Volt ohm Meter, and measure for resistance from terminal to Terminal. you should see at least 10 ohms. Check from Terminal to the metal of the elements to see if the element is grounded to the casing. You should not read resistance here, it should read infinite.
You can get your parts at www.repairclinic.com
