Question about Echo Garden
Pb-250ln throttle - Echo Garden
2 Suggested Answers
jandurand07
  • 8 Answers
SOURCE: My Echo PB-250LN blower is hard to start after carb rebuild and misfire at full throttle. Spark arrestor is clean and fuel is fresh
It sounds like the exhaust is restricting the outlet gas. Try running it without the exhaust. If it runs better, clean or replace the exhaust /mufler.
Posted on May 05, 2016
May 05, 2016 | Echo Garden
Echo pb-250LN how to replace throttle cable
To replace the cable you will need to take it loose at the carb and at the handle and then pull the old cable and housing out and then reroute the new one and hook it up. Hope this helps.
Jul 25, 2015 | Echo Garden
How to install a throttle cable on an ECHO PB-251 blower
throttle cable ??? should actually have a throttle rod that goes to a very short piece of cable. and this cable only goes from the carb to the throttle rod. the cable is actually easy to replace. it's only 3 inches long. the throttle rod or trigger requires removal of one side of the handle.
Oct 19, 2014 | ECHO, Inc. PB-251C Handheld Blower
Echo throttle cable attachment
pb 255 has a throttle rod and a short cable... so you have a rod that comes off of the trigger and it connects to a short cable that goes to the carb
Aug 27, 2014 | Echo Power Blower PB-255
Echo pb 255 throttle cable attachment
try parts tree .com they have decent diagrams..
how many times does one person need to ask the same question
Aug 27, 2014 | Echo Handheld Blower PB-255
Have a PB-250, ran great but now only runs full throttle, does not idle low.
You've been running the unit with the wrong oil to gas ratio and now the unit runs rich - there is no real way to fix it at this point - you can adjust the carb but it will not probably hold the idle you desire - but then again blowers are to be ran wide open 85% of the time so don't sweat it too much on this unit but practice better maintenance and a proper mix ratio in the future.
Oct 05, 2012 | Echo PB-250, Handheld Blower,
2005 Ford F 150 throws p2104 tac system forced idle code frequently.Need advice.
Remove the throttle body and clean the carbon off the throttle plate being carefull not to harm any coating that may be applied from the manf. I use P.B Blaster and a piece of scotch brite pad. spray pleanty P.B on the pad after words clean with a soft cloth. Disconnect the battery to completly clear the code.
Feb 17, 2010 | 2005 Ford F-150
I have an echo gas powered leaf blower, model pb251. it will start and idol, but wont run any faster than that, and throttle cable seems to be ok.
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Apr 02, 2009 | ECHO, Inc. PB-251C Handheld Blower
Garden Logo
35 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
