Question about Razor Dirt Quad Bike
Throttle kicks off while driving while fully engaged and kicks back on
When driving my drive line kicks out of transmission and does not go back in till i manualy put it back in why
I think there is a lack of understanding of terminology in your statement
The drive line is that section from the gear box to the diff or if front wheel drive from the diff to the wheels
If it was to kick out as you say , there is no way that it would go back in as it would be all smashed up under the vehicle
so lets decipher what you are trying to say
The top gear (over drive ) jumps out of gear and I have to physically reselect the gear
would that be what the problem is?
if so then the problem will be from several things
loose gear box on bell housing or failed engine mounts
gear not fully engaged on selection
worn bearings on out put shaft
worn extension housing bush
selector mechanism worn out or loose
It is fixable but if you go to the local garage you will be sold a perfectly good gear box for what is basically nothing wrong
Jun 29, 2015 | Cars & Trucks
How to adjust shift cable
Most kick down cables are fully engaged just before the throttle butterfly is fully open.
Sep 05, 2014 | 2001 Ford Escape
Kohler engine troubleshooting
check condition of air filters. check float level and flow of fuel to carby.
May 27, 2013 | Garden
Kawasaki barako 175B ES repair manual
Here is a procedure I have foud that is very effective. Pull open the choke. Then, open the throttle and SLOWLY operate the kick start lever several times so as NOT to start the engine. Then close the throttle and slowly turn throttle grip until it just starts to open the throttle. Once it starts to engage the throttle, turn about 2 degrees, no more. Then kick start it. Might have to do two or three times.
Jan 31, 2013 | kawasaki Motorcycles
2004 Ford-150 tries to engage in four wheel drive while driving
well you should not be engaging your 4wheel drive while truck is moving is my guess...doing major gear damage
Aug 16, 2012 | 2004 Ford F150
I was cutting a large log and the saw kicked back. Echo GS 300. It now won't throttle up, acting like the kickback safety is locked but it is not. The throttle linkage is still connected also. Any...
Does sound like the brake has activated, pull the hand guard fully back to the top handle until you hear it click off, now try again
Apr 03, 2011 | Echo Garden
Bike wont kick start or idle , it will coast
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle.
When warm, no choke, and a little throttle when kicking.
May 12, 2010 | 2003 kawasaki KX 125
351C with FMX auto, Wont engage drive with high RPM
A CLEVELAND ENGINE IN A FAIRMONT????HMMMMMMMMMMMM....SOUNDS LIKE THE PUMP IS GOING BAD. DO YOURSELF A FAVOR AND JUK THE FMX AND GET A GOOD USED OR REBUILT C-6 INSTEAD.
Dec 15, 2009 | 1983 Ford Fairmont
2002 chev s 10 4x4 won't go in 4 hi.
look on the front axle there will be a plate that a actuator cable is attatched to remove that and chack the spring condition . it sounds like it wants to engage but is not getting fully locked in .
Aug 25, 2009 | 1991 Chevrolet S-10
4x4 transimission clunks when engaged?
When engaging the 4WD system, you are pulling the lever on the Transfer Case right? Not the transmission, it's a different gearbox.
There were several versions of transfer cases that used both full and part-time 4 wheel drive.
From your description this sounds like a part-time transfer case.
Going with that, it is somewhat normal to hear and feel a mild clunk when engaging 4WD high range, especially if you are at a complete stand-still or under full throttle.
Try engaging 4WD High while slowly rolling at idle - no throttle. It should pull in fairly smoothly.
Once 4WD is engaged it will literally LOCK the front and rear axles together. So do not do it on hard dry pavement.
These older style 4WD systems need a little "give" especially when turning. The engineers assume you are not engaging 4WD unless you are in a somewhat slippery scenario.
Many CV joints, axles, U-Joints, differentials, and transfer cases are damaged and broken by folks who don't understand this.
Reading the owners manual should provide a clearer description of what you've got.
Bear in mind that when you come out of 4WD it may not completely release, again due to hard pavement binding up the axles. You can try this: backing up 10-25 feet in a straight line, or getting one set of wheels on the shoulder or in some gravel. That should allow it to release the transfer case and go back to everyday 2WD high.
I hope this helps.
May 14, 2009 | 1996 Jeep Grand Cherokee
Razor Dirt Quad Bike Logo
77 people viewed this question
Top Razor Rock & Ice Climbing Experts
RatanbssBD
Level 1 Expert
Bill Boyd
Are you a Razor Rock and Ice Climbing Expert? Answer questions, earn points and help others
