Gateway fpd1975w monitor, the menu pops up and cannot remove it
SOURCE: power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Posted on May 18, 2008
Bat1956
  • 585 Answers
SOURCE: my gateway monitor FPD1975W 19inch LCD won't turn
I have repaired similar FPD models. I have one of them on this very desk.
The GatewayFPDmodels develop problems after a couple or more years of use. Therepairsare fairly easy for the savvy technician. The power inverterboard inthe back of the monitor contains some capacitors, they may be470 and220 mfd or 680 mfd depending on when they were made, @ 10 16 or25volts, with a 105 deg. C temp rating. They go bad due to heatissuesand the currents they have to filter. Replacement of thecapacitorsusually restores operation. Use capacitorss of the sameratings as original for replacement.
Be advised, turning the monitor off when you are not using it will extend the life between these repairs.
Hope you find this helpful.
Posted on Apr 24, 2009
  • 555 Answers
SOURCE: Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Posted on Oct 09, 2009
SOURCE: my gateway FPD1975W 19 INCH LCD MONITOR DOEN'T
(thank you budmrtn) my monitor shut off..i went online looking for solutions gate way fpd1975w..i looked hard for about 2 hours..i found a common problem was with the power supply..(budmrtn) hit it on the head..i am not an electronic expert at all..i have a soldering gun..thats is..no testers..so i took the monitor apart and found the power supply was a seperate board..i took it out and looked at it and said hmm. do i throw the 180.00 monitor out or do i take a chance..i took the chance..i went to radio shack and bought 10 capacitors like (budmrtn) said i replaced them..if it did not work i was out 10 buck and i was going to throw it away..but well and behold..i replaced the capacitors..just the big ones not the round blue ones..and wala..new monitor..it worked..crazy i no..but it worked..and i have a 19 inch lcd that works and i was going to throw it away..if you need to know what i replaced email me and ill let you know..
Posted on Feb 01, 2010
benwabnick
  • 2404 Answers
SOURCE: Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Posted on Jun 02, 2010
Main menu on the lower right hand side keeps popping up
Sounds like your menu button on the monitor is stuck in the pushed in position. See if that is the problem and use a needle, q-tip with alcohol to pop it back out.
Jan 27, 2013 | Gateway FPD1975W 19" LCD Monitor
Welcome Thank you for exploring the Gateway FPD1975W I can't get rid of it
this message appears during power on and disappears after a few seconds when an input signal from the CPU is detected.If the message did not disappear you can press the menu button on the pannel of the monitor then exit the menu and the message will disappear. good day to you!
Aug 13, 2011 | Gateway FPD1975W 19" LCD Monitor
How do I get my gateway fpd1975w tft lcd monitor to not stretch images images across the screen?
You need to make sure your computer's display resolution is set to 1440x900, which is the monitor's native resolution. Other resolutions will result in fuzzy displays or, as you're seeing, distorted images.
Right-click on an open area of the Windows desktop (that is, not over any icons), then select "Properties" from the pop-up menu. Click the "Settings" tab and you'll find a slider adjustment to set the resolution. If 1440x900 is not offered as a resolution, you'll need to upgrade your video card (or add a video card if you have a motherboard with integrated video). Most newer computers support that resolution, but some older systems may only go to 1024x768.
Thanks for using Fixya!
Oct 20, 2010 | Gateway FPD1975W 19" LCD Monitor
(small text) color is off -- it looks green while should be black. I am looking for a timing table for Gateway FPD1975W. Thanks
mcdevito75 here Try to press the AUTO button on the monitor to restore factory settings to monitor.
Jul 21, 2010 | Gateway FPD1975W 19" LCD Monitor
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
Theft disable menu pops up and won't go away and it keeps turning off my monitor
You need to install EZTUNE from Gateway, but you need to go here first:
Portrait Displays' Theft Deterrence minimizes theft or unauthorized relocation of your display. Theft Deterrence does not prevent the display from being stolen, but hinders the operation of the display once it is removed from the 'Theft Deterrence enabled' host computer.
This site is provided for you to securely store your PIN in the event you should need to retrieve it at some point in the future.
Please select from the following options.
Change your PIN. https://pinreg.portrait.com/change_p...=dtune&OEM=gwy
Forgot your PIN? https://pinreg.portrait.com/remind_p...=dtune&OEM=gwy
User manual:
http://www.retrevo.com/support/Gateway-FPD1975W-Monitors-manual/id/1071ag416/t/2/
Apr 14, 2010 | Gateway FPD1975W 19" LCD Monitor
FPD1975W 19" gateway monitor
The stand is fix,but you can move up/dn little bit..
Jul 06, 2009 | Gateway FPD1975W 19" LCD Monitor
MONITORS
Inverter Power board 19 Gateway Monitor FPD1975w
Apr 09, 2008 | Gateway FPD1975W 19" LCD Monitor
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
