Question about GE Profile JTP18 Electric Single Oven
JS968S0F4SS convection noise
When in convection mode the oven is quite noisy during fan operation (not a rattle more of a loud hum when the fan spins). I have checked the fan and it is not loose. Suggestions for potential sources of noise? The oven is around 8 years old and otherwise in excellent condition.
2 Suggested Answers
  • 417 Answers
SOURCE: convection oven making rattling sound.
It is most likeky that the fan bearing is worn and thus causing the rattling sound. You will probably need to replace the fan. Check first that there is no obstacle in the way of the fan rotating.
Replacement of the fan will require the back of the oven to be removed giving access to the fan unit, which will need to have the wires disconnected and the fan assembly unbolted. Fitting is the reverse.
Always remember to switch off the power before working on electrical equipment.
Posted on Jan 07, 2010
FAN NOISE in convection mode, as in a loud whirring sound, suggesting a problem with the fan. Any one else experiencing this?
FAN NOISE IS NORMAL BUT IF ITS SQUEELING THERE IS A PROBLEM WITH THE COOLING FAN. YOU DO HAVVE TO REMOVE THE OVEN FROM THE WALL TO REPLACE.
Jan 24, 2010 | KitchenAid KEBC107 Electric Single Oven
Loud fan rattling in convection mode
On the repairs I have done, it has always been a bad fan motor bearing. The only way you are going to be able to tell is to tear it down to the fan assembly and feel if the fan blade or blower is loose. Good Luck, Appliance Specialists
Jan 17, 2010 | Ovens
Our fan seems to make a loud rattling noise
Hello, Happy new year ! Now for the oven problem. Do you know if it is the convection fan in the oven cavity or the cooling fan in the cabinet ? If it is the conv. fan, it's quite likely just a loose fan blade. remove the rack's and then the cover of the fan and you should be able to inspect the fan blade and more specifically the retaining nut at the center. You can tighten it if loose,( carefully they tend to bend easy ) but be sure the fan itself isn't bent or damaged in some fashion. If that doesn't solve the problem let me know I'll try to direct you to the cooling fan, however it is much more involved and I typically suggest a pro tech. Hope this help's, good luck and thank's for visiting "fixya" today. Macmarkus :)
Jan 01, 2010 | Zanussi Ovens
Kitchenaid convection oven fan rattles/noisey
Sometimes the fan blade mounting nut gets loose. Remove the cover from the fan and see if the blade wobbles. If so,tighten the nut on the fan motor.
Jul 27, 2009 | Moffat Half Size Electric Convection Oven...
Very noisy fan
Hi
you need to replace the fan as this will be the cooling fan which cools the oven down. and can not be disconneted .
regards
Mar 21, 2009 | Kenmore Ovens
NOISY OVEN
Yes, it can be fixed quite simply.
First check that the fan is not catching the cover or grill, if it is not remove panel covering fan and see if the fan blade is loose,on the shaft, they are usually held on by a left handed nut., so to tighten go the oppisite way to what you normally do, if that does not cure it, then your only solution is to replace the fan motor complete.
Plz rate my solution.
Thanks, and a merry xmas.
Dec 21, 2008 | Ovens
GE Profile JTP18 Electric Single Oven Logo
50 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
