Question about Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
My Dane Elec USB drive stopped working. It's full of important data. When I plug it in it keeps flashing. The computer can see it but when I try to access the data it shows a malfunction. I tried two different computers and tried rebooting with the drive plugged in. It actually stopped the computer from booting. I really need the data. It's confidential medical info and I can't let it out of my sight.
  • 136 Answers
Access it through RUN and copy paste it somewhere on hard disk.
Posted on Oct 16, 2013
2 Suggested Answers
kamal1984
  • 1383 Answers
SOURCE: Not recognized by any computer
no it is supported on high speed or usb legacy 2.0
Go to bios setup and setr usb legacy 2.0 high speed
then save settigns
Posted on May 25, 2009
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
My usb device was working fine until yesterday when I plugged it in and I kept getting an Unknown device error with the following message: "Windows has stopped this device because it has reported...
Code 43 errors are nearly always caused by a driver issue. However, since you have tried the device in several different computers with the same result, I believe that your flash drive has gone bad or become damaged. Unfortunately this is not an uncommon problem with flash drives. Like any storage device on the computer, make sure you are backing up what is on your flash drive.
I hope this is helpful to you
May 28, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Put in my dane elec 16 gb flash key on my computer window ex and other computer window 2007 not recognized its malfunctioned. light is out... need to get all my important files out..
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htmwww.CardRecovery.com
Apr 20, 2011 | Dane-Elec DaneElec 4GB USB Drive Blue Hard...
I have a Dane-Elec 4 GB Flash drive. I used it successfully one time, but the next time I put it in my computer (or any computer after that) the computer recognized the new device but told me "Please...
1) Instead of double-clicking, right-click and choose "explore." I hope it's that simple. Once you're in, look for a file called autorun.inf. Delete it.
2) If it won't let you explore, see if there is a "format" option instead. This will possibly solve your issue of access, and will solve your issue with your confidential data (of course, your data will be gone, but I'm guessing you're OK with that).
3) Try using another USB slot, sometimes there could be an issue with specific slots, especially if you are using hte front USB ports on a desktop
4) I know this may seem silly but turn off the computer, and then unplug the computer from the wall. Leave it unplugged for 30 seconds, plug it in and then boot up the systems. Plug in the USB drive.
5) Finally if the unit still is not being seen, it may need a low level format, contact the manufacturer and see about getting a replacement. I found their e-mail at onlinesupport@dane-memory.com
Feb 27, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane Elec 4gb USB Not Readable
Try it in a different computer or even a different usb port on the computer that you are using. If a second computer gives you the same error, then the drive is either damaged or its filesystem is corrupted. In the first case there is not much you can do. In the second case you may be able to reformat it to make it work, but you would lose any data that was on it.
Mar 25, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
My pc havet a drive for my flash memory
If you want to format to remove all the data from your flash drive and wipe it clean you do not need a program as you can do it through windows.
Step 1 - Plug in your flash drive to a working usb port Step 2 - Click on start and then click My Computer. Step 3 - Find your memory stick. In most cases drive C is your hard drive and drive D is your disc drive. This means that your memory stick is most likely drive E. It is a removable storage device and not your hard drive. This is very important because you don't want to format your hard drive. Step 4 - Back up any data you want to keep from your flash drive. When you are done with the formatting everything will have been removed from it. Drag the files you want to keep from your memory stick onto a folder on your computer. Step 5 - In your My Computer folder right click on your flash drive icon and click format.
Mar 18, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Missing driver for dane elec 4gb usb flash pen (Operating system XP)
No zMate Pen driver is necessary to work out with Windows Millenium, Windows 2000, Windows XP and MAC OS 9.1 and more: they are plug and play.
but try this site:
http://www.dane-elec.fr/scripts/home/publigen/content/templates/TPL_ADV_INFO_C2_S4.asp?P=352&L=EN
Jan 11, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
I cannot open my flash drive on any computer. Will I be able to recover the data?
Sounds terminal, have you tried laptops to plug into. Can you see the drive letter in "My computer" if so then scan it with good antivirus program.
If not probalby dead with non recoverable data.
Dec 01, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Can't place files on my Dane Elec Usb stick
Well maybe it's full... check.. Maybe it's "Protected" in some way... maybe it needs to be "Shared" in permissions.. otherwise maybe it has gone kaput... hope not.. GL
Jul 25, 2008 | Electronics - Others
Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive Logo
Top Dane-Elec Computers & Internet Experts
Steve
Piyal Perera
Piyal Perera
woodzowl307
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
