Question about Intertherm P3RA-048K Air Conditioner
I ahve a amerite camper and when I turn the air on or the fan on i hear it humm but does not come on.is there a rest wsitch some where?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
Sounds like if your hearing it hum it is either a bad capacitor or motor
Posted on Oct 15, 2013
Unit it working, but no cold air is coming throughout the house
check condensing unit outside, the fan could be turning but the compressor could be off if this is the case turn the a/c off for about 10 minutes then turn it back on an hear if the compressor is trying to start. you should hear a loud humm if the compressor is trying to start but can not, if this is the case is likely that you have a bad capacitor. there are other causes for the compressor not starting this is the most common. always follow safety guidelines when working with high voltage.
May 30, 2011 | Goodman Heating & Cooling
Ac cools camper fan blower turns off compressor
hi there,
ac not cycling off,the thermostat is not working
have to replace a new one.havve anice day fix my rate thanks
May 14, 2010 | Dometic Rooftop RV Air Conditioner
Have a duo therm penguin heat pump a/c when turning it on the compressor humms but no fan. the fan gets pretty hot upon the roof after 20 sec of operation. the main hot wire to the unit is pulling 18.5...
check the cap for the fan. Will the fan start if you spin it when you hear the humming. Check the lock rotor amperage for the compressor to see if it is hung up. The cap if it is shared could knock out both the fan and comp so check both.
Aug 12, 2009 | Heating & Cooling
Brick Air blowing hot air
if you hear the compressor turning on,no heat, the coolant has leaked out. if the compressor doesnt turn on, its a control issue.
Jul 25, 2009 | Heating & Cooling
My duo therm roof top camper air conditioner just shut off and will not come back on. Can hear a click when turning on now but nothing else. Note that heater will not come one either.
The click that you are hearing is the relay control board in the rooftop unit. This means that you are getting 12V to the board. It sounds like you are not getting 120V to the AC unit. Check the breakers in the breaker panel to make sure they are OK. If they are fine, then turn off the AC for 5 to 10 minutes and try again. There is a thermal protection device in the unit that prevents you from turning it right back on after a shut down. Try putting the thermostat to fan only operation. If the fan does not come on in fan only mode, then you have thrown a breaker.
Hope this helps,
Jeff
Jun 27, 2009 | Dometic Rooftop RV Air Conditioner
Blower fan is not coming on
I recommend you getting service its a safety thing. the humming is the transformer and is normal.. good luck Tom
Jun 22, 2009 | Ruud UBHC Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Fan not working
the humm could be the contactor check the breaker for the out side unit or see that you have power at the unit dan
Jul 17, 2008 | Carrier 38CKC036 Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
19 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
