Question about Garden
Need pdf instruction manual on rebuilding carburetor for my lawnboy mower (not sure where to find model#?) 4.5hp Gold series push-mower. NOT self-propelled. Maybe a 1997-98?
  • 2 more comments
  • grantmongstu Apr 23, 2009
    2 cycle engine
  • grantmongstu May 12, 2009
    the you tube video link was very clear and helpful. much better than a manual. Thank you!
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello mr g,i really need that model number it is on the body usually located on the deck rear,it is a silver sticker,there are so many lawn boys 2 cycle,
  • JERRY ABELL
    i could help you if i knew what brand of engine you are talking about lawn boy uses three different engines
SOURCE: Lawnboy F series Engine - how to remove PLATE AND COLLAR ASM
shaft is tapered plate just slides up on shaft, tap with hammer several times if want break loose,sometimes moisture has rusted it or excess heat has swelled it on tight, i had to take a drimel tool will cutting disk to remove mine,then clean up shaft with file or sandpaper to smooth,little grease an new collar ready for blade.
Posted on Jun 15, 2009
  • 133 Answers
SOURCE: Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Posted on Aug 16, 2009
  • 202 Answers
SOURCE: rerunning the belt on an o6 self-propelled Lawnboy
You may have to loosen the adjustment a bit to let the transmission tilt farther forward. Do not loosen the other nut on the adjustment, that way you will know how far to re-tighten the one you loosened when you have the belt on.
Posted on Jan 26, 2010
witserv
  • 144 Answers
SOURCE: ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS,
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Posted on Jun 14, 2010
  • 6 Answers
SOURCE: How do I replace the primer bulb on my lawnboy
You must remove the engine cover (three torx screws) then you can pull the line off the plastic bulb disk and remove it from the cover by pushing the side clips.
Put silicone on the bulb disk and force the bulb on to the disk. I had to use a vice to hold the disk, it is a very tight fit. When you get the bulb on the disk, reinstall it in the engine cover and reattach the hoses. The gas tank hose will probably need to be pushed on to the carberator and the gas tank also. This is hard work but is the only way you can instal the bulb.
Posted on Sep 20, 2010
Lawnboy model 10415 serial number 5901752 correct spark plug
Joe, Factory Lawn Boy SPARK PLUG 614009, replacement plugs champion CJ14, NGK plug # BMR4A.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Boy 10415 Lawn Boy Gold Series Walk Behind Mower 1995 SN 5900001...
614009 Spark Plug
Which spark plug for Lawnboy engine
https://www.shoplawnboy.com/Comergent/en/US/adirect/Toro?cmd=ToroLBOnlineModelLookup
Aug 04, 2016 | Garden
Lawn boy push mower wont start spits fuel out of exhaust
This is a hard one to diagnose without seeing it but it could be a sticking float or a stuck open valve. If you have good compression you can eliminate the valve issue. Be careful checking the float that the inlet needle doesn't fall out.
Aug 22, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Oil mixture for 1985f series 2 cycle lawn-boy mower
Contact your dealer ! but 32:1 sounds correct. 8 ounces of Lawnboy oil to two gallons of gasoline ....is 32:1, 8 ounces of oil to one gallon of fuel is 16:1 for the real old lawnboys,
When Toro bought out OMC,and started using Tecumseh mowers,the ratio changed in the late 80's or early nineties ! IIRC :o)
Jun 11, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Lawnboy 10665 won't self-propel and impossible to push
If you have the smell of rubber burning the belt isn't gripping. Make sure that there isn't anything stopping the wheels turning like old grass or even a piece of twig. If their clear try adjusting the tension on the drive pully.
Jun 28, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Lawnboy mower will not idle up under load
the lawnmower is not designed to idle with a load on the engine, it needs to be operated at full throttle
Apr 10, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
I would push the prime button 3 or 4 times it starts then quiet
I took my carburetor off and blew it out with compressed air. Runs great now. Make sure to get all of it. Little screw on bottom has a hole in it too!
Apr 18, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Apr 12, 2009 | Garden
Garden Logo
432 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
