Question about Fujitsu Office Equipment & Supplies
I'm using a Fujitsu Scanner 6670. When I have the job cache set to use both memory on the computer and scanner. It scans every other page. When I turn the job cache off it scans all the pages. This happens to both Duplex and non duplex. All the pages go through, but when it spits them into scanall it only shows every other page.
4 Suggested Answers
mohanchennai
  • 490 Answers
SOURCE: Duplex Scanning
If the line appears in the same location, it is definitely dust sticking to the glass. How thick is it? If it is thick, it may be because of an LED failed to glow, but this is etremely rare. If you are getting line in Duplex mode and not in simplex mode, it is on the second scanning module! Try cleaning with Isopropyl Alcohol (IPA). If you have been scanning old documents which tend to break like biscuit or get powdery, a speck can enter into the scanning area and create trouble.
S. Mohan
Posted on Mar 05, 2008
mohanchennai
  • 490 Answers
SOURCE: scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Posted on Jun 13, 2009
mohanchennai
  • 490 Answers
SOURCE: Getting vertical lines on scanned pages when
It is dust on the glass, clean it thoroughly. You will find it at the same location for all drawings and may get faded for lower brightness!
S. Mohan
Posted on Jul 10, 2009
What can be done to fix my fi-6670?
You may need to lubricate the moving parts. I had a printer that was playing up like this and the bars that the print head moved on needed a tissue with a small quantity of machine oil to be rubbed on the bar to allow the print head to move freely. If all the scanners are the same age the lubrication they had may have worn off.
Apr 29, 2014 | Fujitsu Fi 6670 - Document Scanner -...
Fujitu FI 6670 service manual
Fujitsu has documentation for all of their products on their website.
Here is a list of all the scanner docs:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/docs.html
For the FI-6670 they link to 3 different documents:
Datasheet [587KB]
Getting Started Guide [1.39MB]
Operator's Guide [12.7MB]
Jan 31, 2014 | Fujitsu fi Office Equipment & Supplies
Fi-6670
Here is the operation guide:
http://www.fujitsu.com/downloads/COMP/fcpa/scanners/fi-6x70_ops-guide.pdf
Dec 17, 2013 | Fujitsu Fi 6670 - Document Scanner -...
Fujitsu Fi-6670. I have a little (microscopic) piece of paper stuck under the lower screen, so when scanning it appears a blu line over the whole page. How can i get it out? Thanks
Hello Alex,
You need to open the scanner and de-assemble some parts to remove the piece of paper which involves technical expertise. I would recommend to contact a Fujitsu scanner technician or call your nearest service center for assistance.
Thanks & regards,
ScanCare
Aug 28, 2013 | Fujitsu Fi-6240 Flatbed Scanner
What's wrong if i get error e9
E-9 error in Fujitsu fi-6670/fi-6770 is the Image Memory Alarm which implicates scanner memory malfunction.Turn off and turn on the scanner, does the same symptom still occurs? If yes, then you may have to replace the DIMM located at the memory slots on the CGA board. If the issue still persists after replacement of DIMM, then you may have to replace the Control PCA. I would recommend to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jul 17, 2013 | Fujitsu fi-6770 Flatbed Scanner
Error e9 on fi 6770 means what?
Thanks & regards,
ScanCare
How do I set up my scanner to scan multiple pages at once, without having to keep hitting the scan button. ( fi-6140 )
Hi, are you using Scannedallpro software? If so, press the batch scan setting button (2nd right after the white drop down menu). This will give you access to your settings. Select add, name your new profile appropriately, then select SCAN, Click SHOW CONFIRMATION WHEN NO PAPER IN ADF, then click on Detail Scanner Settings. This will take you to your options screen. Select either Duplex, for double sided or ADF Front side for single sided. You can choose to drop out blanks by clicking on the OPTION button at the bottoms of the screen, then JOB/CACHE, click the selection button for Blank Page Skip and choose the sensitivity. (I usually use a low setting). Click OK.
when happy with your settings click OK again, then apply.
Use your new profile to batch scan. The system will scan until the hopper is empty and should ask if you want to continue with the same batch scan, allowing you to add paper until the job is complete.
NB Always ensure you have selected Multi Page Tagged Image File Format as the system will not save your scan as one document without it.
Hope this helps!
Nov 10, 2010 | Fujitsu fi-5120C
The fujitsu fi-5110C won't scan all pages just takes the whole thing and just scans the first page. Is there a setting where you can make the scanner to scan each page one at a time? thank you :)
Please follow the information provided below:
If all the pages are being fed through ADF and if image format is TIFF, then you may require another application to view the multi page TIFF image. If you're using ScandAll 21 or ScandAll Pro application for scanning, you have to choose multi page scan option in Batch Scan Setting. Please follow the help contents provided in the scanning application.
Hope the above information is helpful. Please revert if you have any doubt.
Regards,
TechSatya
Jun 29, 2010 | Fujitsu fi-5110C ScanMaker Scanner
Fi-5750C Fujitsu scanner can't change grayscale default setting
Photoshop is not an "advanced" scanning program. To get some "production" and value out of this expensive scanner you need a professional scanning program which also may control the settings of the scanner. Use PixEdit which utilizes the built-in jpeg compression in the scanner. Did a test scanning 10 pages A4 duplex fullcolor. Adobe Acrobat Pro used 4 minutes. PixEdit used 20 seconds. Guess Photoshop (in your version) would also scan uncompressed and not use this good scanner optimal.
Jun 26, 2009 | Fujitsu fi-5750C Flatbed Scanner
DR-9080C intermittent stops during scanning which last 3 to 5 minutes
Do you have enough hard disk space? Reinstall your driver software. Run Scandisk on the Comp.
Is the problem coming on after a set time interval, any heating smell?
S. Mohan
Jun 22, 2008 | Canon DR-9080C Path-Through Scanner
Open Questions:
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
