Whirlpool dishwasher fills with water when off.
  • Official Brand Answer
  • 362 Answers
Hello Miles. My name is Melanie and I am a representative of Whirlpool. We apologize about the frustration you have experienced with your dishwasher. If you would like us to look into this further, please provide your name, the name of the site you were contacted on (Fixya.com), your user ID name (Mile Backman), your phone number, your address, the full model and serial number, and ticket number (61353) to Whirlpool.Digital@Whirlpool.com. We would be happy to review your concerns further. Sincerely, Melanie
Posted on Oct 14, 2013
Testimonial: "THank You for asking. i found the answer quickly. it was the inlet valve....i found a video on changing the inlet valve here on my exact model....i love FiXya.. for me its money in the bank :-) Miles"
Whirlpool dishwasher just keeps filling? help please
check on the floor of the dishwasher on front left side. There should be a round float that is the overflow cut off. \make sure that it will go up and down. This is what shuts off the water.
Mar 07, 2014 | Whirlpool Dishwashers
Whirlpool Dishwasher will fill water then stops
If it fills with water properly then stops, and especially if there is a humming noise, it is possible that
- motor start capacitor has failed
- drive belt has slipped or snapped
- belt tensioner spring has broken
Nov 07, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher doesn't clean very well
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Whirlpool Dishwashers
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwasher fills with water by its self.
yes you do the valve is very easy to replace located
at the bottom left of the d/w make sure to shut that power off
Apr 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool DU1055XTP dishwasher fills with water but won't wash.
Can you be more specific? Does the dishwasher fill and then overflow?
Apr 11, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwasher wont fill
I fit won't fill then apparently you're not getting any water to it, which means it not's fixed. Did you turn the service valve back on since the repairs were made? Sometime when you turn a service valve off they fail to re-open. Crack the inlet water line and verify that you have incoming water.
Jan 18, 2009 | Whirlpool 24 in. DU1050SS Built-in...
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
