Question about GE Refrigerators
Service manual for ge pfss6pkxcss will not make
Service manual for ge pfss6pkxcss will not make any ice but water despinser workss
4 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: how to replace water tank on ge pfss6pkxcss refrigerator
Here is a link to the instructions per the Service Manual=> GE PFSS6PKWASS Water Tank Removal and Installation Instructions If you have questions I will be here to assist you, Thanks Sea Breeze
WR17X12468 Asm Water Tank and Here=> WR17X12468 Asm Water Tank
Posted on Jun 04, 2013
Sea Breeze
  • 4654 Answers
SOURCE: GE Eterna series Ess23xgsbb That the ice maker
I cannot be positive about your refrigerator but the defrost thermostat is what turns the defrost heater off. If not working properly the defrost cycle will either become longer and hotter or no defrost at all. All decisions about when to defrost comes from your refrigerators mother board on the back of the refrigerator. There is no defrost timer or Adaptive Defrost on your model. So I am sure it is a problem of too long into defrost or too hot . So in short something either the mother board or the defrost thermostat is the problem, Sea Breeze
Posted on Aug 22, 2009
  • 1218 Answers
SOURCE: no water coming from ice tube b4 this started ice
Good day, Here's the checklist. step by step, should solve your problem..
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Feb 04, 2010
How to replace water tank on ge pfss6pkxcss refrigerator
Jun 03, 2013 | Refrigerators
My GE Monagram Ice maker is not making ice. I have cleaned with approved cleaner for the clean cycle and it does not seem to help. The water just seems to flow over the freeze plate and periodically a thin...
I don't have the service manual for this model without having to purchase one but I have a link to Whirlpool Service Manuals which is very much the same when it comes to diagnostics. There are several reasons that may cause this problem as you described. They are water control valve sticking causing warm water to continue to flow over freeze plate and stopping ice production. A defective condenser fan or a very dirty condenser coil. Link to Whirlpool 15 inch and 18 inch Ice Maker Service Manual Link to a site where there are information and answers for most model ice makers HERE You can contact this person at the bottom of the page, Thanks Sea Breeze
Mar 06, 2013 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram ZISW36DYA ... frozen ice-cycle rivulets run down both sides of freezer (water off for days to verify it is not ice maker) ... defrost control clicks when rotated and advances with time ... do...
Seems to me that might be a clogged defrost drain or maybe a dripping water valve. Doing that. I have the service manual with nice pictures in it that show clearly how to access the components.
GE MONOGRAM SERVICE MANUAL
Nov 10, 2010 | GE Monogram Side by Side Refrigerator
I have a GE Profile refrigerator Model # PSC23MGTC it has an Artica Water & Ice dispenser on the freezer door, the ice will not come out, and noew the water works only when it wants to, I think I need...
Cut and paste this Factory Service manual for your refrigerator.
The troubleshooting guide will help locate the bad part.
http://appliancejunk.com/ge/refrigerator/31-9072.pdf
Aug 08, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Water is working but the ice maker has stopped making ice
That's a duel valve with separate solenoids, I would be willing to bet the solenoid is broken on the water valve.
Profile service manual
Ice maker manual
May 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Eterna series Ess23xgsbb That the ice maker makes and but the despinser keepe freezing over. We have taken it out and defrosted it and with in 48 hours it frozen over again
I assume you're talking about the ice dispenser and the ice bin being frozen over.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube and causing the water to spill into the ice bin. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
