Question about Pioneer PD-M423 CD Player
Clean laser lens
Ticking and skips
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Laser worned out...
Posted on Oct 18, 2013
Skips and doesn't play CDs
I'm guessing this is a CD player?
Try to open the lid and with your finger (without touching the laser lens) move the lens toward the outside edge. Sometimes the gears that move the laser skip and this will re-set it. If not try cleaning the lens with an alcohol cleaner.
Oct 16, 2012 | Audio Players & Recorders
CD'S Skip and start all over on my RCA RS2663 Player
laser lens cleaners dont work real well you need to clean the laser with spirits
good luck its deffinitly the laser
Jun 25, 2010 | RCA RS2663 Shelf System
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Denon s-102 skipping parts on DVD (only)
dirty lens, look for a DVD lens cleaning kit
Aug 11, 2009 | Audio Players & Recorders
My cd player skips
Unplug the unit, remove the cover and clean the laser lens glass with a Q-tip. Spray a bit of window cleaner on one end of the Q-tip (over a sink), then use that end to clean the objective lens of the laser. Then dry it with the other end. Wipe Carefully!
Do not apply pressure while cleaning, wipe slowly and then reassemble the unit and test. This is a common problem on many laser-based products, dust and smog get inside the unit and cloud the lens, causing it to skip or not read at all.
Feb 24, 2009 | Sony D-NF420PS CD Player
My dvd player is skipping on every movie, i adjusted the laser, and cleaned the laser with canned air.. but it still skips!! Do you have any solutions to this problem?
hi most of the time a cleaning disk or canned air is not enough, you have to open your dvd player and clean you laser lens whit a cotton swabs and alcohol do not use peroxide. Do it slowly and be careful.
and can a know what do you meen by "adjusted the laser"
bye and good chance.
Dec 03, 2008 | Televison & Video
Jvc kd-g502, cd player skips constantly. has been cleaned could the cache need cleaning and how?? Carol
Common skipping issues can be:
Scratched discs, recorded cd-r's on poor/cheap media, dirty laser lens, disc spin motor binding, laser asm. slide rails needing re-lubed. Of course defective components can cause it as well.
Geno
Mar 05, 2008 | Audio Players & Recorders
Skipping
Have your laser lens cleaned or buy a dvd lens cleaning cd available at radio shack. cost around 15 dollars.
usually when the laser lens builds up dust on or around laser lens players tend to skip.
Jan 14, 2008 | Mintek LCD TV Progressive Scan DVD Player
DVD'S SKIP
Open the top cover and remove the laser housing cover. You should see what looks like a door-hole peeper which is the top lens on the laser itself. Using a "lightly" windex coated Q-Tip carefully clean off the top area of the lens and put the covers back on...
If the unit still skips then it's probably time for a new pick-up table and it will require a bit more testing in the shop to determine the failure.
Hope this helps!
Bill
Nov 13, 2007 | GoVideo DVR4200 DVD Player/VCR
PLaystation2
I dun't know, but mine does the same thing! Silver satin right?
try cleaning the lens with a DVD laser cleaner disc, I bouth one at Walgreens for about $12.00 it's Scotch brand, has a few brushes that gently clean the laser, dont touch them tough cause u can get oils from ur fingers on it, if not use a Q-tip with rubbing alcohol, not too wet! and gently in a curcular motion clean the lens! GENTLY! ... if all that don't work, and the game's not scratched, the laser could be bad, I heard that the laser sucks on the PS2!
Oct 13, 2007 | Sony PlayStation 2 (PS2) Console
Pioneer PD-M423 CD Player Logo
95 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
