Question about iCandy Apple Stroller with Flavour Pack Grape
Left handside off Apple 2 pear when you push the handle pushes down and feels very insecure! Right hand side feels secure. Has something broken in left stem?
  • iCandy Master
  • 1,629 Answers
Hi Euan
We would advise you to contact your iCandy retailer or contact iCandy customer care for the country you're in for them to be able to provide assistance.
Posted on Oct 27, 2013
Left handside of handlebar slips down when pushing it and feels very insecure-has something broken?
What type of motorcycle is it ? You will need to at least tell us what make and model of motorcycle it is. Most general brand motorcycles have either a full bar that acts as both handlebars. There are a few brands that have a "center cap" that when the bolts are tightened the cap squeezes down on each individual handle bar. If yours is like that then i would start with seeing if directly between your handlebars and right above your forks if there is a plate with bolts through it. If there is then check to make sure that those bolts are tight.
Oct 11, 2013 | Motorcycles
Have an older style XTS boogie 2 pram. Got it second hand and can't remember how to fold the chasi down. please help! I've pulled the red button thing on the right hand hinge but nothing...
Gosh, this is testing my memory! I believe that there is a black lever on the handle bar. This is on the left hand side. Place your hands in the normal pushing position, then slide your hand down and following the natural curve and underneath where the hood sits there should be a lever type thing (can't think of a better way to describe it!). Press this lever down, then release the red button on the right hand side, then push the handle toward the floor, that should do it.
Hope this helps.
May 20, 2011 | Baby Gear
I have been trying to turn on my chain saw. Ive pulled the handle back by the trigger gave a few pull on the rope. then i pushed the button in on the side also the push the button back in by the trigger...
The chainbrake should be activated when starting the chain saw. Activate the chain brakeby pushing the front hand guard forwards.b>Cold engine Start position, 1: Set the start/stop switch in the choke position by pulling thered control outward - upward.Decompression valve: Press the valve to reduce the pressure in the cylinder and makestarting easier. Once the machine has started the valve will automaticallyreturn to its original setting.Air purge: Press the air purge diaphragm repeatedly until fuel fills thediaphragm (at least 6 times). The diaphragm need not be completely filled.Grip the front handle with yourleft hand. Hold the chain saw on the ground by placing your right foot throughthe rear handle.Pull the starter handle, 4: Pull the starter handle with your right hand and pull out thestarter cord slowly until you feel a resistance (as the starter pawls engage)then pull firmly and rapidly until the engine fires.Push down the red choke control: As soon as the engine fires which can be heard through a"puff" sound, push down on the red choke control.Pull the starter handle (6): Keep on pulling the cord powerfully until the engine starts.
Nov 18, 2010 | Husqvarna 450 e-series 18" Chain Saw
First time driving a 1967 Triumph motorcycle coming up. Would like advice on where stuff is like clutch, brake, shifter and how to shift -- where the gears are. Thanks. Art asanfelici@verizon.net
Hi Art! First of all, congratulations on your 1967 Triumph... that's a beauty!!!
Basic things to know before riding a bike is it's parts.
Clutch is the lever you press on the left side of the handle bar.
Front disc brake is the lever on the right side of the handle bar.
Shifter is the one you're stepping on when shifting gears and is located on the left side of the engine if you're on it.
Now, you must first know if the gear is on Neutral by pushing the bike before starting the bike. If it's hard to push then the shifter is not in neutral. Press the shifter by your left foot until you are able to push the bike with ease.
Hop on the bike and start the engine. Most bikes have ignition starters but if your bike doesn't have one, then you have to turn keys to on position and use the kick starter. Rev the engine by pressing the throttle grip on the right side of the handle bar.
Engine is running and in idle position. Press the Clutch lever (left hand) and press the shifter once (left foot) DO NOT RELEASE THE CLUTCH YET!!!
Slowly press the throttle with your right hand until you hear or feel the engine purr...
Slowly release the clutch (left hand) until you fell the bike move forward.
If I am not mistaken, shifting the gears of the triumph is 1-down and 4 up...
Every time you shift gears, you need to press the clutch to release the gears.
Hope you'll have fun!!!
Ride safe my friend!!!
Don't forget your riding gears!!!
^_^
Jun 22, 2010 | 1993 Triumph Tiger
How to replace belt for hoover elite vacuum
http://www.hoovervacuumbelts.net/
How to replace
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from
cleaner body.
4. Remove agitator and broken agitator belt. (If belt is not broken but is stretched or cut, proceed with steps 7-10 and pull belt off motor pulley. Then continue with step 5.)
5. Slip agitator through new belt (with lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into
opening in cleaner body. Reposition agitator making sure to
align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
May 29, 2010 | Hoover Elite U5061-900 Bagged Upright...
Have bought second hand mutsy stroller, no manual and no idea how to fold the chasis down!
First remove the seat or carrycot/car seat if this is on the chassis. Then, stand to the left of the chassis. Push down the button on the handle which lowers the handle bar height with your right hand. With your left hand, take a hold of the black cuff on the side of the chassis (this should be about waist height). In one movement, you need to pull the left hand up, whilst pushing down your right hand, this needs to be done at the same time, and with some force.
When the chassis is lowered toward the floor, this will click shut. To open the chassis, there is a small metal arm on the left hand side of the chassis with a red cover on (this is quite little) you need to lift this button upwards (towards you) and the chassis will open.
I hope this helps.
Nov 13, 2009 | Mutsy 4Rider - Red Stroller
To open pushchair i need to turn it upside down ,get on my hands and knees and make a complete fool of myself ,i must be doing something wrong.....please help
The best advise that I can give is the following:
Kneel behind the stroller.
Push in button 1 (the left hand-side) with the heel of your hand, whilst keeping this depressed, push button 2 with the heel of your hand, then whilst your hands are still pushing the buttons in, use your thumbs to push the frame forward - the buggy will then semi fold forward. Push the cross-bar between the handle bars away from you, this will release the elbow joint.
Then, simply push the pram toward the floor, this should fold the pram fine.
NOTE this does take a little practice, but if you stick with it, you will get it.
I hope this helps.
Sep 15, 2009 | Quinny ZAPP Stroller
Quinny buzz
Tyres-press the light grey button on the chassis next to the wheel slot as you push on the wheel (this is also the button you press to release each wheel).
Opening it is easy - With Buzzwheels on the ground, remove safety hook (plastic loop on left side of handle fixed to peg inner left rear wheel) ten simple lift handle and Buzz frame should automatically pop up.
Closing takes more practice-put on brakes (press red foot pedal) stand to side of chassis and at bottom end of handle there are two large grey buttons. With left hand on left button push button forwards (ie direction of chevrons on button) then press in. At the same time push in right button with right hand. Whilst doing this you also need to push down and forad on frame and it should fold down. If you don't push buttons enough it can click. When folded remember to put on safety hook before transit, otherwise it might pop up on its own. Hope this helps. You can download the manual with instructions from Quinny website too if pictures are helpful!
Apr 25, 2008 | Quinny Buzz Jogger
Mutsy Urban Rider
Hi guys, I had this problem when I first got my urban rider - the trick is to put the seat on correctly in the first place. If you look under the front of the seat (when seat is facing away from mum/dad) you'll see 2 plastic hooks - these need to be hooked over the first horizontal bar of three that you can see (it has a small black plastic nobbly bit on it) then, as you were doing, push the handle and pull the 'tube'. If the seat is facing you (child travelling backwards) it won't fold, neither will it fold with the carry cot attached.
Hope this helps! Tegans mum x
Feb 14, 2008 | Mutsy 4Rider - Pink Stroller Frame
Right door handle upside down pinches fingers. how to remove and flip?
mirellis, grab the handle with both hands and push in and up. The handle will slide off the retainer clips. To put them back on, line up the clip holes push in and pull down. I never tried flipping them, but you will find out real fast. This is for the GS6NBEXRL model that was posted, Catriver.
Nov 30, 2007 | Whirlpool GS6NBEXRL Side by Side...
iCandy Apple Stroller with Flavour Pack Grape Logo
Top iCandy Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you an iCandy Baby Gear Expert? Answer questions, earn points and help others
