Question about Emerson Mw9339sb Microwave Ovens
Model mw9339sb not heating - Emerson Mw9339sb Microwave Ovens
How can I find the specs for a microwave oven transformer?
Check with a local appliance parts distributor.
Dec 27, 2015 | Microwave Ovens
How do I correct a microwave that runs automatically with a display when connected to power outlet but does not heat up anything. The kitchen timer,clock and all other buttons works except express coo
Check and replace magnitron with one of the same number or equivalent.High tension transformer fuse may be blown or high voltage diode and or capacitor shorted. N.B. Please disconnect applance from mains and discharge large capacitor before carrying any DIY on any microwave,
Nov 07, 2014 | Emerson Microwave Ovens
How do i replace the light bulb in emerson microwave model number mw9339sb
Check if it has a cover screwed in side the unit , it should be behind that.
Nov 01, 2014 | Emerson Microwave Ovens
MW9339SB broken door latch
There are no user serviceable parts on microwave ovens, due to the danger of running one without the door in place. You will need to take it to a service centre. All of the screws are security screws that you need a special tool to remove.
Feb 20, 2014 | Emerson MW8987B/W Microwave Oven
Emerson microwave oven model mw9339sb has an arcing magnetron
The magnetron is supposed to make an arc to work but when it is getting out of hand it will sound wrong. At that point it is time to change the large capacitor and the magnetron. If there is an arcing inside the cabinet then you have to look for missing powder paint. Don't use any metal racks in a microwave or they will arc.
Dec 01, 2013 | Emerson Mw9339sb Microwave Ovens
Runs but not heating
if turntable does not turn it may be a issue with a safety switch--no heat can also mean inverter board (power) or Magnetron unit bad---both are pricy parts.
Nov 04, 2012 | Emerson Mw9339sb Microwave Ovens
My GE microwave, model #WES1450DM1BB; serial #SM908139U, shows
When I try and heat some food, the microwave runs but doesn't heat anything, its a model wes1450dm1bb
Mar 15, 2009 | GE XL1800 1100 Watts Microwave Oven
Emerson Mw9339sb Microwave Ovens Logo
24 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
