Question about Samsung SCX3405FW - SCX-3405FW Wireless Multifunction Laser Printer,
MY SCX3405FW PRINTER CUTS OFF SOME PRINT AT THE RIGHT MARGIN COPIES GOOD FROM THE TOP. SAME FROM TWO DIFFERENT PC'S. CAN YOU HELP THANKYOU
  • 120 Answers
Your printer roller got some problem. please contact your nearest samsung service centre
Posted on Oct 18, 2013
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
The printer cuts off the top part of the document when printing. Is this a margin issue?
Yes, most likely your application's margin settings are incorrect. Try printing a test page - NOT from the application. If this is Windows, go to printers in control panel, right-click on the subject printer, choose Properties, then click the Print Test Page button. You should get the standard Windows printer test page with the logo at the top and all the printer specifics below. If the test page is also cut off, look around in the HP-provided software for any margin and/or page size settings that are incorrect, such as A4 paper when it should really be Letter size.
Feb 18, 2011 | HP Officejet Pro L7680 All-In-One Printer
I need to print some cards with my printer, is it possible to reduct margin to zero? I have created the document without margins, but the printer cuts part of te documents... thank you for your help!
This is normal. Practically all printers have a 'non-printable area' which forms a border at the top and bottom and left and right hand sides of the page. Whilst your software may allow you to work with a zero margin, your printer is physically incapable of printing in the non-printable area and will simply cut-off any text or images that overflow into this region.
The best solution is to reduce the number of cards on your page so that you can bring the text back within the printable area of the page. Then print with normal or wide margins and trim the excess from your cards.
Mar 19, 2010 | Canon PIXMA MP210 InkJet Printer
Only copies half a page. Right margin cuts off
check paper trays to make shure paper is tight in guides. registration settings off
Jan 09, 2010 | Sharp Office Equipment & Supplies
My E-mail when printing on my HP Officejet J5780 cuts the right 1/4 page off at the right margin: appears that the font and picture sizes are enlarged and is cut of at the right hand margin.
that is not unusual, as emails are non formatted for printers, you may find that making the page 'scale' to the paper in print setup panel, will help this.
Nov 24, 2009 | HP Officejet J5780 All-In-One InkJet...
The printer will print OK from the desktop, but when I print from emails it cuts the right margin back about 2" - nothing will print on the right hand side of the page. I tried dumping the driver program...
Dear Glenn27,
As you mentioned, printer works fine normally however the issue is only while printing emails.. so I would like to know the email program that is in use .. I mean, do you use Outlook, Outlook Express or webmail or Lotus notes etc..
If this is a repeated question then I would like to apologies as we experts are not allowed to peep into other experts' solutions so I cannot see the responses by the previous expert.
Also please let me know the following printer settings ..
AUTO WRAP, RIGHT MARGIN, LEFT MARGIN,
What happens when you copy the email text to a standard text editor like Notepad or Ms Word and then try printing .. does it still print with right margin extended?
Waiting for your response.
Regards,
Srinivas
Jun 24, 2009 | Brother HL 1650 Laser Printer
Printed Tape Cuts Off Letters
I was having the ame issue. Found the solution on the user manual (posted online). Press Function, scroll to "Margin", press "Function", use arrows to select "#" or "##", then press Function again. Now it should print with a margin, thus not cutting off your letters. Mine was set to "-", which is basically no margin.
Dec 29, 2008 | Brother P-Touch 1180 Label Printer
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
Margin printing problems
Check your application's print settings (for e.g. MS Word). Then check the printer's properties and print settings. If nothing works you also try re-installing the latest printer driver. If you use MS word should check the page setup option, for paper size errrors. If the color of your margin is red and the red ink is out then you won't se the margin line.
Oct 09, 2007 | HP Color LaserJet 2600n Printer
Samsung SCX3405FW - SCX-3405FW Wireless Multifunction Laser Printer, Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
